Old 02-08-2020, 09:26 PM #1
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
At what mileage did you change your v6 timing chain?
I'm just curious. What's your mileage when you changed your timing chain? I'm at 150000 miles now and change my oil every 10000 miles or 1 year. So far, I've never had a problem. If you can share your experiences, I would really appreciate it. Thank you.
radlynx is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 10:20 PM #2
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
There's no need to change your chain.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 10:53 PM #3
Bigshankhank Bigshankhank is offline
Real Name: Tyler
Bigshankhank is on a distinguished road
Real Name: Tyler
You change your oil every 10,000 miles?
2008 4Runner SR5 V6 4WD
Bigshankhank is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 11:02 PM #4
Yotascape's Avatar
Yotascape Yotascape is offline
Yotascape will become famous soon enough
Yotascape's Avatar
I was thinking the same, better off at 5k intervals
Yotascape is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 12:23 AM #5
andreylights's Avatar
andreylights andreylights is offline
andreylights will become famous soon enough
Changed my at 125k - was having a check engine light
andreylights is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 12:27 AM #6
little_titan little_titan is offline
little_titan is on a distinguished road
Yup no need to replace your timing chain, only timing belts need to be changed.
In addition, start changing your oil every 5k-6k (if using synthetic oil) and that will prolong the life of your timing chain.
I replace my oil twice a year (5-6k). Once before winter and once before summer time.
little_titan is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 07:26 PM #7
2003-4x4runner's Avatar
2003-4x4runner 2003-4x4runner is offline
2003-4x4runner will become famous soon enough
Im still on the original timing chain at 254k miles.
2003 V6 BLACK SR5 4X4-Runner
OB #1334
https://www.instagram.com/ob_1334/?hl=en
Dad's Travel Service.
We drive around till we find it. No map's needed!
2003-4x4runner is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 12:06 AM #8
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
Hopefully I never have to do this.
Your best defense is staying on top of your oil changes. Read: Timing Chain Stretch: It Is The Oil's Fault!
10k is probably fine with a synthetic, but oil is cheap and oil changes on our v6s are easy. I change every 5k with a full synthetic.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 03:26 AM #9
truc.karl truc.karl is offline
truc.karl is on a distinguished road
I changed mine at 150k.
truc.karl is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 09:05 AM #10
Real Name: Tyler
Real Name: Tyler
For reference I change my oil every 5k with a synth-blend. Engine is just over 250k with nary a tick.
Timing chain is original and should outlive me. My biggest problem is I've never changed the trans fluid, but it is on my list to do a fluid exchange in the next couple weeks before spring.
Old 02-10-2020, 10:36 AM #11
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
I replaced my chain after it stretched at 120k. The dreaded P0016.
techno is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 02:21 PM #12
GreatZen GreatZen is offline
GreatZen is on a distinguished road
I'm at 513,535 miles, and I still have the original chain. Also, not that this suddenly on oil change thread but I use Mobil 1 Extended Performance and change every 15k+.
GreatZen is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 06:21 PM #13
lightfreak lightfreak is offline
lightfreak will become famous soon enough lightfreak will become famous soon enough
I’ve had oil analysis done on various synthetics and the TBN is still quite high after 6-7K miles. The oil is still comfortably within spec and hasn’t sheared down.
10K is no problem on the V6 with any reputable brand of synthetic oil.
I think checking the level frequently and topping up is probably just as important as regular oil changes. If the chain is starving for oil it’s going to heat up and wear out faster.
I’m also on the original chain.
2004 4Runner Limited V6 4WD ***SOLD***
385,000 Km
Titanium Metallic
Vehicles: '21 Highlander XSE V6 AWD | '21 Acura RDX SH-AWD Tech | '03 Honda CBR600F4i
lightfreak is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 08:13 PM #14
GJ675's Avatar
GJ675 GJ675 is offline
Real Name: G.Jenkins
GJ675 is on a distinguished road
GJ675's Avatar
That's always wonderful to hear! I hope I get many miles out of my 08 T4R. I also used MOBIL 1. I use it on my motorcycle chain instead of chain lube. Thin coat applied as needed. No wear on sprocket or chain in over 13k miles. I am hard on the throttle too! The claims Mobile 1 state are fact
GJ675 is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 10:30 PM #15
newton22 newton22 is offline
newton22 will become famous soon enough
What model year? Any other issues? Head gasket?
2004 SR5 4WD | 5100s | Level 8 MK6s
newton22 is offline   Reply With QuoteReply With Quote
chain , change , mileage , miles , timing
Timing chain and chain dampers (guides) replacement - When? SomeDay Classic T4Rs 5 01-21-2018 08:22 PM
Timing belt? or Timing chain? MNguns General Discussions 3 06-24-2013 12:06 AM
help pls - timing belt or timing chain? weifert Maintenance/Detailing 2 10-22-2012 07:12 AM
Timing Belt change - time not mileage? TeryT Maintenance/Detailing 4 02-03-2011 12:51 PM
Timing Belt vs. Timing Chain White4runner Engines / Suspension / Wheels / Tires / Audio / Accessories 3 10-21-2003 06:32 PM
