Old 02-11-2020, 08:01 PM #1
micosavo's Avatar
micosavo micosavo is offline
micosavo is on a distinguished road
micosavo's Avatar
Kenwood Radio Reboot Issues
To other folks with After Market Radios:
Do any of you guys have issues with your Head Units randomly rebooting?
I've reseated the fuses, the battery is good, mechanic confirmed there is no draw when the car is off, but sometimes it reboots and sometimes it turns itself back on, even when the car is off!
Any tips would be most helpful.
Cheers
Mike
2005 Limited V8, Kenwood DNX893s, Steelcraft Front Bumper, Toyota Bug Deflector
161k Miles
micosavo is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 04:37 PM #2
AceSpades AceSpades is offline
AceSpades is on a distinguished road
Sounds like to 2 separate issues.
The rebooting may be the radio itself being faulty. But turning itself on, even when the car is off sounds like it isnt wired properly. It should not get Accessory power until you turn the ignition key to "ACC" or "ON".... Or the Ignition switch itself is faulty and sending power to the ACC when its OFF. Is it only the radio that turns on? Check cigarette lighter to see if that is on also when the radio turns itself on. If not, then the radio is wired "Hot" all the time on the ACC side
AceSpades is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 05:11 PM #3
benztech82's Avatar
benztech82 benztech82 is offline
benztech82 will become famous soon enough
benztech82's Avatar
I have seen it few times actually. Usually it happens when iphone is synching contacts and other crap. Try wiping/factory restore of a radio, at least delete phone and don't allow it to connect. Test radio without phone being connected.
Sent from my Redmi 4 using Tapatalk
benztech82 is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 11:23 AM #4
bearisasquare's Avatar
bearisasquare bearisasquare is offline
Real Name: Topher
bearisasquare is on a distinguished road
Real Name: Topher
First thing I would do is recheck the wiring installation. Make sure the harness and connector wires are all connected correctly. Its possible during installation, especially if butt connectors were used, that they may have a loose connection. Check and recheck this with the wiring diagram as well to make sure the power is connected to acc and not 12v live or some other wire from the vehicle that could be giving it intermittent power.
If everything looks ok, i would start with the unit and try factory resetting and upgrading to the latest firmware. If you still have an issue, it could be the unit itself. You may want to reach out to the manufacture for some clarity.
2009 Limited 4WD V6 Shadow Mica
ICON Stage 2 Kit SCS Ray10 17x8.5 BFG KO2 285/70r17
Rago Modular Storage Panels & Ditch Brackets * Prinsu Rack * Baja Designs Sqaudron Sports
KC Hilites Cyclones under hood * Blue Sea 12 Circuit Fuse Block * White LEDs Interior
Kenwood DMX906S Kenwood X802-5 Amp Infinity Front REF-6530cx & Rear REF-6532ex Pioneer TS-A2000LD2
bearisasquare is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 09:17 PM #5
evan1242's Avatar
evan1242 evan1242 is offline
evan1242 will become famous soon enough evan1242 will become famous soon enough
evan1242's Avatar
Which installation harness is being used?
Is it the JBL sound system?
Many of the cheaper after market data harnesses can cause the radio to restart or even turn on when the car is off.
This is normally not because of a wiring problem. The harness is always supplied constant battery power and when you turn the ignition it receives a data signal to tell it to turn on, which the harness converts from digital down to a regular 12v analog “turn on”
So sometimes this radio replacement harnesses will sometimes tell the radio to turn on or off when it shouldn’t.
Also check to make sure there are not any software updates available for the radio.
Like the other person said also sometimes the phones contacts can be a problem. I know it’s weird but I happens. Only if you have an iPhone and some of your contacts start with a number.
evan1242 is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 12:18 PM #6
grad061980 grad061980 is offline
grad061980 is on a distinguished road
I'm not sure what brand you have, but I have a Kenwood Excelon DNX996XR. I have idatalink and connect my phone to the Kenwood via wireless Android Auto. It will randomly reboot and has been since new a few months ago. I see a lot of people posting that it is a firmware/software issue with Kenwood.
'17 Limited // Shrockworks trail rockers // Shrockworks rock slider w/ dimple step // '16 trail wheels. // Cooper Discoverer AT3 LT265/70R17 // AVS Low Profile Dark Smoke Ventvisor
grad061980 is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 02:12 AM #7
hunterD1 hunterD1 is offline
hunterD1 is on a distinguished road
if you have the maestro RR that may be the issue... i had random reboots months after install drove me nuts trying to figure out why, ended up getting an maestro RR2 for the extra programmable options and BOOM no more reboots.
hunterD1 is offline   Reply With QuoteReply With Quote
car , fix , friend , s420 , years
1998 4Runner. Rear hatch dead. No wiper, no power window, license plate lights, etc.. tgreathead 3rd gen T4Rs 24 01-23-2023 02:19 PM
2001 SR5 4WD - Is the transmission dead? 2001fr 3rd gen T4Rs 34 09-13-2022 12:55 AM
Bringing her back from the dead... (build thread) gnarlydavidson 3rd gen T4Rs 3 11-27-2017 09:07 PM
1998 key removed, radio still on. was random, but now battery dead imonyourcouch 3rd gen T4Rs 5 10-31-2012 11:53 PM
Back from the dead - sort of ? KellyJ 3rd gen T4Rs 29 11-27-2008 11:32 AM
