Old 02-12-2020, 01:34 PM #1
winstonrodney's Avatar
winstonrodney winstonrodney is offline
winstonrodney is on a distinguished road
Wheel bearings - should I replace both or just the bad one?
I have a bad front wheel bearing. Going to have it replaced next week by my trusted shop.
My question to the greater forum knowledge base is: Should I replace both of the front wheel bearings or just the one that went out?
2007 with 180k on them.
2007 SR5 - 2" OME lift, ASFIR skids
winstonrodney is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 01:44 PM #2
Drunner97's Avatar
Drunner97 Drunner97 is offline
Real Name: Danny
Drunner97 will become famous soon enough Drunner97 will become famous soon enough
Drunner97's Avatar
Real Name: Danny
I'd just do both and be done with it for awhile. Front bearings are an easy swap. I'd just buy the completed assemblies and do it yourself, save some money.
build thread: https://independentoffroading.com/in...xit-thread.30/
IG: @4runner_doa
Drunner97 is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 01:51 PM #3
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
I have replaced 100s of bearings professionally over the last 20 years. seldom if ever do I do both at the same time. in fact, I rarely change the other side on the same vehicle. most people sell their rigs before the other side goes. I say rarely, because some vehicles have an issue with bearings. toyotas do not seem to be one of those.
if the other side is tight, and not making any noise, it could give you many miles and years of trouble free service.
however, for piece of mind, you can absolutely have them both changed. this is something I have done for some customers over the years. the one thing about wheel bearings though, they typically give you ample warning before catastrophically failing. so its not like you would suddenly be stranded somewhere because one goes out, if you don't change it today...
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 02:02 PM #4
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
if you don't mind me asking, what symptoms are you experiencing? I have a droning sound that I can't make out if it's coming from the wheels or one of the diffs. Thanks
CookieRoe is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 02:22 PM #5
Yep, it's a droning sound coming from the front. I initially thought it just road noise from my snow tires I had just put on. But a good friend who happens to be an ex-Toyota mechanic rode with me and instantly said "sounds like a bearing's going out." It's gotten slightly louder as time has gone on. I can't point to a specific time when it started, but could be 5000 miles ago, maybe longer.
Old 02-12-2020, 02:23 PM #6
Thanks for the advice! I'll have my guy check the other and see if it's tight.
Old 02-12-2020, 02:29 PM #7
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
I've worked on vehicles professionally for 16 years. I never do more than the one that's bad. Get the HUB unit and swap it out yourself in short time and get back to enjoying your vehicle. Cheers!
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 03:54 PM #8
hamel hamel is offline
hamel is on a distinguished road
Had a shop replace drivers side, but passenger side was still good.
It gave out about 2 years later. I did that one my self with a preassembled one from Marion and it was a quick job with the right tools.
hamel is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 05:27 PM #9
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
does the droning youre referring to happen at low speeds while turning?
my buddys hyundai elantra had wheel bearing replaced from a whining sound straight on highway...while i noticed taking a right hand turn at low speeds i hear a rotational sound, almost tire sounding, wondering if its wheel bearing or something hub related. i cant hear anything troubling at speed or going straight.
hinmo24t is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 10:58 PM #10
TannerW's Avatar
TannerW TannerW is offline
Real Name: Tanner
TannerW is on a distinguished road
TannerW's Avatar
Real Name: Tanner
I replaced one and then the other one went out about 1,000 miles later while I was on a road trip without any tools on me. Like previously stated I would just replace both for peace of mind.
1996 V6 SR5 260k
2006 V6 SR5 150k
TannerW is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 11:10 PM #11
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
If you start replacing everything that might be at 75% +/- lifespan on a 180k mile rig, you're going to have some hefty repair bills. I replaced 1 wb on my GX a couple years and 20k+ miles ago when it had more play than I like, other 3 are still fine. Even when I did a full front end refresh on my GS I didn't touch wbs. You'll know when they need it, with plenty of time to spare.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 02-27-2023, 08:18 PM #12
andes andes is offline
andes is on a distinguished road
Thanks for the advice, I'm just going to do the one side, and maybe I get another 50k from the other side
andes is offline   Reply With QuoteReply With Quote
Old 02-27-2023, 08:19 PM #13
does the OEM hub unit have a part number or various part numbers?
Old 02-27-2023, 10:33 PM #14
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough
I just replaced the bad side and kept the other new wheel bearing in my garage.
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 02-27-2023, 10:53 PM #15
07 SR5 4x4
bad , bearings , front , replace , wheel
5th Gen Front Wheel Bearings - When did you replace yours? Randyman... 5th gen T4Rs 20 03-11-2022 02:28 PM
its time to replace front wheel bearings kolelt 3rd gen T4Rs 23 09-02-2018 07:44 PM
Should I replace my front wheel bearings? eurasiaoverland 3rd gen T4Rs 7 04-25-2016 06:57 PM
Don't wait replace your rear wheel bearings! bigskyeric 4th Gen T4Rs 2 02-04-2016 05:03 PM
Need to replace rear wheel bearings ShannanC 3rd gen T4Rs 2 10-24-2015 04:20 PM
