Old 08-15-2016, 01:07 PM #1
BOFFROAD's Avatar
BOFFROAD BOFFROAD is offline
Real Name: Brad
BOFFROAD is an unknown quantity at this point
BOFFROAD's Avatar
Real Name: Brad
Help! Traction control, VSC Trac, VSC off light, are all on after body lift install
Yesterday I installed the toytec 1" body lift. Now every time I drive the vehicle after about 1 minute the slip indicator, VSC Trac, and VSC off lights come on. Iv'e seen a few threads on these lights but nothing relating it to the body lift. Can I go get the codes read on this?
2005 Sport V8 4WD Gray
Icon Stage 2 | 285/70/17 BFG KM2 | MB 352 17x9" wheels | 42" led light bar | Side Flood/Camp Lights | Uniball UCA's | K&N CAI | Kicker Sub and Amp | Custom DIY Full Length Roof Rack | Trail Gear 67"
Rock Sliders
Build Thread
BOFFROAD is offline   Reply With QuoteReply With Quote
Old 08-15-2016, 03:29 PM #2
BOFFROAD's Avatar
Real Name: Brad
BOFFROAD's Avatar
Real Name: Brad
Can it be Zero point calibration that it needs? Even though I think that it is usually caused by an OBD scanner.
Rock Sliders
Build Thread
Old 08-15-2016, 03:33 PM #3
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
My guess would be either it needs a ZPC or you stretched a wire somewhere.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 08-15-2016, 03:43 PM #4
zonarunner zonarunner is offline
Real Name: Bradley
zonarunner is on a distinguished road
Real Name: Bradley
Disconnect your battery for a few reconnect. See if it doesn't reset it. I've had to do this a few times.
Silver 2005 4runner, Rodger brown 1.5" body lift, led exterior lights, led relay, hid headlights, painted headlights, blacked out emblems, front bumper, rock sliders, limo tint. 05 f250 axles, King 14 duel rate coilovers with remote reservoir, front and rear ARB lockers, 5.13 nitro gears, ballistic fab mounts and joints, rough stuff steering links, Toyota steering box, RST speed sensor, fj duel stick transfer case. 40x13.5r17 nitto trail grapplers.
zonarunner is offline   Reply With QuoteReply With Quote
Old 08-15-2016, 03:45 PM #5
CXS CXS is offline
Real Name: Chris
CXS will become famous soon enough
CXS CXS is offline
Real Name: Chris
^ Stretched abs wire is my thought too.
Chris - '07 SR5
‘05 Limited - sold
CXS is offline   Reply With QuoteReply With Quote
Old 08-15-2016, 04:06 PM #6
BOFFROAD's Avatar
Real Name: Brad
BOFFROAD's Avatar
Real Name: Brad
I disconnected battery for about 10 minutes and checked all brake wires near the master cylinder which all seem good without any stretching. The lights still come on. Does anyone know of more locations of the ABS or VSC wiring. I also want to state that I haven't done any traction control mods.
Rock Sliders
Build Thread
Old 08-15-2016, 04:42 PM #7
CXS CXS is offline
Real Name: Chris
CXS CXS is offline
Real Name: Chris
Check this thread: VSC and ABS light on after lift and tires installed?
Chris - '07 SR5
‘05 Limited - sold
Old 08-15-2016, 04:54 PM #8
BOFFROAD's Avatar
Real Name: Brad
BOFFROAD's Avatar
Real Name: Brad
Actually the battery disconnect did to fix it. Thanks for the help. Didn't think it would be that easy. I will check that thread if they come back on.
Rock Sliders
Build Thread
Old 08-15-2016, 04:56 PM #9
Utopia's Avatar
Utopia Utopia is offline
Utopia is on a distinguished road
Utopia's Avatar
That's is my thought as well
2006 V8 Sport, TRD pro wheels, General Grabber AT2 265/70, Daystar 2.5/1.5 lift
Utopia is offline   Reply With QuoteReply With Quote
Old 08-15-2016, 04:57 PM #10
FactoryT4R FactoryT4R is offline
FactoryT4R is on a distinguished road
I had this happen to my IS300 once and it was the ABS sensor wire was damaged... ALL those lights were on.
2013 Limited 4X4 | 1F7 | NAVI | Bilstein 5100 | Cornfed | JBL | DDM Tuning | TYC | MileMarker | VLED Triton | Ultra
FactoryT4R is offline   Reply With QuoteReply With Quote
Old 08-15-2016, 05:09 PM #11
luke87gt's Avatar
luke87gt luke87gt is offline
luke87gt is on a distinguished road
luke87gt's Avatar
Let us know if the battery disconnect was a permanent or temporary fix.
If temporary, signs point to stretched wire.
2006 4-Runner XSP V6
SCS Ray10 17x8.5 (Matte Black)
Falken ATW3 Wildpeak 265/70/17
Daystar 2.5/1.5
luke87gt is offline   Reply With QuoteReply With Quote
Old 08-16-2016, 02:20 AM #12
BOFFROAD's Avatar
Real Name: Brad
BOFFROAD's Avatar
Real Name: Brad
I will, so far after a few more drives today everything is still good.
Rock Sliders
Build Thread
Old 08-16-2016, 04:10 PM #13
jfry008's Avatar
jfry008 jfry008 is offline
jfry008 is on a distinguished road
jfry008's Avatar
When they come back on do a ZPC...note the orientation of your ODBII plug, it is upside down from the picture here. Use a paperclip or short wire to make the connections.
08' 4Runner SR5 4WD V6 Level 8 MK6 wheels//Kenwood DDX9903s//JL 10W3v3 on 500/1//LEDs//ICON Ext Coilovers FR//Metaltech LT Rear Springs w/ Dobinson LT Shocks//JBA UCAs//spidertrax//5th gen brakes in front//295/70/17 Cooper Maxx//SS brake lines//http://www.toyota-4runner.org/4th-ge...ld-thread.html
jfry008 is offline   Reply With QuoteReply With Quote
Old 12-13-2019, 11:14 PM #14
Carm1962 Carm1962 is offline
Carm1962 is on a distinguished road
VSC \ VSC off lights
I don't have an answer, but I have a similar situation. I replaced the timing belt and water pump. Everything sounds and feels fine, but when I put the truck in gear and begin to move, both the VSC / VSC off lights illuminate. They do not illuminate when I start the truck, only when I begin to move forward or reverse. I would really like to get them to turn off.
Carm1962 is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 11:01 AM #15
_kbarb _kbarb is offline
_kbarb is on a distinguished road
I installed a Toytec Boss 3" lift in my 2003 4runner over the weekend. I drove the 4R after the install for about 30min and no lights came on. At the alignment shop, the VSC Trac and VSC Off lights came on. The tech "tried to reset them" (whatever that means) but they didn't go off.
Based on this thread, we used a voltmeter to continuity test all of the ABS sensors. They all tested fine.
I took the 4R to the dealership for diagnostic where they determined it needed a ZPC reset which they did inclusive in the $75 diagnostic fee. Now we're back in action!
_kbarb is offline   Reply With QuoteReply With Quote
VSC on/off, VSC Trac, Traction Control AND ABS Lights on. RunnerJeff 4th Gen T4Rs 40 08-03-2022 06:16 PM
VSC/Traction Control/ABS/VSC TRAC lights ccvortex 4th Gen T4Rs 7 06-11-2016 04:18 PM
VSC TRAC light on, traction control issues? Skips in acceleration Dext77 4th Gen T4Rs 2 10-31-2013 01:26 AM
VSC off and traction control light problem Bama Ho Runna 4th Gen T4Rs 11 10-30-2013 05:57 PM
VSC trac, VSC off, and ABS light on after lift install, WTH! chrisdowling84 3rd gen T4Rs 8 06-24-2013 11:02 PM
