Old 02-12-2020, 03:30 PM #1
RivMan's Avatar
RivMan RivMan is offline
RivMan has a spectacular aura about RivMan has a spectacular aura about
RivMan's Avatar
"Ignore" V6 head gasket issue?
So my 2006 4Runner (11/2005 build date) seems to have caught the head gasket bug at 227,000 miles. I noticed it was losing coolant slowly a few months ago, and this past week has developed a Cylinder 2 Misfire on startup that goes away in ~10 seconds.
Has anyone with this issue "ignored" it for a few months with no ill effects? What about the opposite, ignored it and ended up with a huge failure?
I plan to tackle this issue myself with a top end rebuild, new gaskets, resurface heads, new timing chain, etc... However I want to wait until spring when my other two cars come out of hibernation.
Thanks
-Rob
RivMan is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 04:22 PM #2
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
My friend with Tacoma with the 4.0 had a headgasket failure. Should have been a simple job, but the machine shop found one of the exhaust camshafts to be cracked, adding $600 to the already sizable bill. He had ran it for quite some time with symptoms until it finally threw a code. Not a car guy, so just pretended there wasn't a problem until the ECU said there was.
YMMV
Keros is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 06:39 PM #3
bricew25 bricew25 is offline
bricew25 is on a distinguished road
I think your biggest worry would be overheating at some point and then warping your heads. At that point, a rebuild may be out of the question.
I know I have a small head gasket leak on my 05, but I have decided to do an engine swap if the day ever comes. Im just running this engine into the ground
bricew25 is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 11:07 PM #4
newton22 newton22 is offline
newton22 will become famous soon enough
I would use a head gasket sealer like Blue Devil. Even if you're not sold on the idea, you can clean out all of it via an engine rebuild + flush.
I plan to use a bottle as soon as my head gasket starts leaking a bit.
2004 SR5 4WD | 5100s | Level 8 MK6s
newton22 is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 05:04 AM #5
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
You will be fine. If it starts misfiring all the time, then proceed with the repair.
radlynx is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 11:07 AM #6
RivMan's Avatar
RivMan's Avatar
Thanks guys!
A couple more months of winter and I can take the truck down for a while to rebuild.
-Rob
Old 02-13-2020, 11:23 AM #7
Elan750's Avatar
Elan750 Elan750 is offline
Elan750 will become famous soon enough
Elan750's Avatar
I went months with an early sign of a HG leak. Then it got totaled, im so glad I put it off haha.
2005 4Runner Sport 4wd v6 -totaled!
2003 Lexus GX470
Elan750 is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 06:21 AM #8
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Talking
I have a 2005 V6 4runner with 150,000 miles. No HG problems, but I'm gonna try that Blue Devil when and "if" it shows up.
Runs like a top and coolant level has been perfect for 15 years.
Keep checking your coolant level in your overflow canister. If you get a bad engine miss at startup and white smoke out the exhaust, get it fixed.
Mrs. Linda Veri-Azzara posted on LinkedIn
Captsolo is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 02:17 PM #9
400k&counting 400k&counting is offline
400k&counting is on a distinguished road
My 03 has had a HG leak for 230k miles. I just change my one spark plug every 3rd oil change. I have around 430k on the clock
400k&counting is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 02:57 PM #10
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
for sure. youre in the one place youll find all the outliers among tens of thousands of 4runner owners in the world
hinmo24t is offline   Reply With QuoteReply With Quote
Old 03-05-2020, 09:26 AM #11
Outfront Outfront is offline
Outfront is on a distinguished road
Head gasket sealer was put in my v6 by previous owner. It overheated on me because this stuff clogged my radiator and it burst at the seam. When I repaired HG, I flushed many chunks of this sealer crap out of the coolant system.
I don't recommend it.
05 v6 2wd HG repaired at 183000 miles. Also new radiator, timing chain, water pump & hoses, installed trans cooler,
new serpentine belt w/ tensioner and pulleys.
05 SR5 v6
Outfront is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 11:47 PM #12
ruckerz ruckerz is offline
ruckerz is on a distinguished road
I oddly have the same issue, cylinder 2 misfire only when cold, 185k miles. On mine though, the exhaust gases are leaking into the coolant, as evidenced by strong smell when I crack open the radiator. I also noticed that the coolant rises when I start the car cold, indicative of the exhaust gases building up. Short of the long, you’ll probably blow out a coolant line or crack your radiator or overflow your coolant tank as well. And that pressure build up will likely prevent the coolant from circulating around when the engine has low rpms (like idling in stop and go traffic) leading to an overheat.
I’m readying to replace the gasket when I get the head bolt bihex in the mail in a few days. Other than that I’m not driving it.
ruckerz is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 08:54 AM #13
sonicc sonicc is offline
sonicc is on a distinguished road
Please don't use the head gasket sealer. It can work, sometimes, but whoever ends up rebuilding your engine is going to hate you for it, and if you're the one rebuilding it you'll hate yourself.
It's * probably * ok to drive for a short time if it's a small leak like you say, but the longer you drive like that the bigger the chance of warping the head (assuming it's aluminum) because you'll have more heat in that spot.
sonicc is offline   Reply With QuoteReply With Quote
Old 11-06-2020, 02:24 PM #14
How do you know whaT BRAND OF HG SEALER THE PREVIOUS OWNER USED?
Whether BD will work depends on the severity of the HG leak. Read this Amazon review (the first one). OP has gone over 30,000 miles (two years) with the BD.
Amazon.com: Customer reviews: BlueDevil Head Gasket Sealer (38386)
2005 4runner SR5 with 150,000 miles and never an overheat or HG issue. Purchased new from Toyota dealer for $44,000 cash. To date never a check engine oil warning light, but have replaced three starters.
Old 11-06-2020, 08:51 PM #15
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
I'm dreading the day when I have to deal with this. There have been two instances in the last 20k miles where it misfired at startup. The most recent time was today. When it did it I immediately ran to the back and smelled the exhaust for the smell of coolant, and thankfully there was none. Mine has 287k miles on it so when/if the head gasket blows I'll probably just replace the engine with one with lower miles. And it will definitely come from an 06-09 model so I don't have to stress about this anymore.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
gasket , gaskets , head , issue , months
Wondering about 4.0 V6 and Head Gasket @#6 "issue" blackmax 4th Gen T4Rs 58 02-15-2023 01:52 AM
My "solution" to the charcoal canister clicking and "thupping" issue Orion K 3rd gen T4Rs 3 04-07-2020 08:40 PM
3VZE head gasket advice "PLEASE which side is up" Qbert General Discussions 3 10-20-2014 08:19 PM
Just joined the "Head Gasket Club" Coctailer Classic T4Rs 19 05-25-2012 05:10 PM
"sniffer" says bad head gasket - believe it? iamburanto Classic T4Rs 4 09-15-2006 03:02 PM
