Old 02-14-2020, 10:15 PM #16
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Originally Posted by ZLJUANN View Post
Survey says.... It dropped a valve. Looks like ill be pulling the head off. Piston looks nicked up but I didn't see any significant damage. I will document some more as I pull the head and see what caused it.
Attachment 354364
Hopefully it isn't too bad. Doesn't look like it ran too long like that. Get another head off ebay and slap it on there and I bet it's good.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 10:27 PM #17
ZLJUANN ZLJUANN is offline
ZLJUANN will become famous soon enough
The beauty is that I have a perfectly good donor head from the engine I pulled off my other 4Runner. If the piston and cylinder check out, I’ll just be out gaskets and time.
ZLJUANN is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 11:08 PM #18
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
That's even better!
Old 02-15-2020, 09:50 PM #19
Putting closure to the thread.
Pulled the head in 5 hours from start to finish, with a lot of breaks and messing around.
Turns out that the valve took out the rod so the engine is coming out regardless.
There were no signs of valve train damage with the valve cover removed but once I removed the cams I saw that the exhaust valve dropped because the retainer failed. Timing belt was tight and everything was timed properly.
I’m basically out 5 hours of a Saturday. At least the engine will come out a lot easier now with the intake and 1 head off. One thing I did realize is that it’s surprisingly easy and fast to get to the timing belt. I could probably turn it around in 4 hours, but I am an experienced wrencher.
Old 02-16-2020, 05:06 PM #20
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Well, it was worth a shot at least! Gal you got it figured out. Hopefully the motor swap goes easy and you can find one or piece it together on the cheap still.
Old 02-18-2020, 11:49 AM #21
Would people find it beneficial if I published my time lapse of pulling the head?
How about pulling the engine? The service manuals are very thorough but they do miss some details or don’t explain some well. I know I didn’t find a specific write up with pictures when I pulled the last engine.
Old 02-18-2020, 11:57 AM #22
spartacus's Avatar
spartacus spartacus is online now
spartacus's Avatar
I would defiantly watch it.
spartacus is online now   Reply With QuoteReply With Quote
Old 02-18-2020, 12:01 PM #23
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Hell yeah, that would be awesome.
Old 02-18-2020, 08:39 PM #24
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Yes indeed, do it please, it will help many here now and in the future!
2004 Limited V8
Old 05-02-2020, 11:55 AM #25
Well here’s a link to a YouTube video of me pulling the engine out after following the manual.
After doing it twice, the easiest method for sure is pulling the trans vs trying to leave it on. Do yourself a favor and get a trans jack if you ever have to do this. I think it was a 6 hour process round trip and you can see how slow I’m working on this one lol.
YouTube
decided , driver , engine , finally , plug
Trouble restarting when engine is hot giro Classic T4Rs 10 03-09-2014 01:33 AM
More Engine Trouble. Kill me now. 4Running Daily 3rd gen T4Rs 48 05-24-2013 11:04 AM
87 22re engine trouble clutch1087 Problems & Warranty Issues 0 06-24-2012 06:47 PM
'93 Engine start trouble buddha724 Classic T4Rs 2 12-11-2008 12:13 AM
? about engine trouble code 24 YotaGuy Classic T4Rs 4 11-30-2008 07:41 PM
