Old 02-12-2020, 09:35 PM #1
bearisasquare's Avatar
bearisasquare bearisasquare is offline
Real Name: Topher
bearisasquare is on a distinguished road
Real Name: Topher
Factory JBL Amplifier Replacement
Anyone replace the factory JBL amplifier? My sub has blown and I would like to go ahead and just change both.
Goal is to install an amp that fits in the same location. If possible, I'd like to get an idea of how much room there is to work with before disassembly. Has anyone installed an aftermarket 5 channel amp here?
Edit: I already have a new head unit (Kenwood DMX906S and swapped out the front woofers and tweeters with components. Just need to know the size of an amp that would fit in the stock location.
2009 Limited 4WD V6 Shadow Mica
ICON Stage 2 Kit SCS Ray10 17x8.5 BFG KO2 285/70r17
Rago Modular Storage Panels & Ditch Brackets * Prinsu Rack * Baja Designs Sqaudron Sports
KC Hilites Cyclones under hood * Blue Sea 12 Circuit Fuse Block * White LEDs Interior
Kenwood DMX906S Kenwood X802-5 Amp Infinity Front REF-6530cx & Rear REF-6532ex Pioneer TS-A2000LD2
bearisasquare is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 10:33 AM #2
Seasparrow Seasparrow is offline
Seasparrow will become famous soon enough
I do not know if this is yours also(YouTube) . Part of the problem is that this system uses some 2 ohm speakers which means mix and match is difficult. The amp is between the head controller and the speakers and most systems today have amp in the head unit.
The harness may be a problem as well, Some stereos have 2 antennas, mine has 1 powered and 1 not, the ones built into my rear side windows are actually powered.
Replacing the system is often reffered to by the folks that have done it as "all or nothing". This includes the harnesses. You may also need to interface with the steering wheel, and navigation system if you have them.
Crutchfield is a company that has a little higher prices but guides you through the process using your runners model and year.
Here are some of those post
Has anyone replaced factory JBL AMP with aftermarket?
Installing Pioneer radio
I want to replace my stock stereo... any suggestions?
JBL system replacement ADVICE
Audio Upgrade?
Factory JBL Amplifier Replacement-wiring-diagram-1-jpg  Factory JBL Amplifier Replacement-wiring-diagram-2-jpg  Factory JBL Amplifier Replacement-wiring-diagram-3-jpg
NATO Seasparrow Mk 57 Mod 2 & 3
2004 4th Gen Sport Edition
Seasparrow is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 11:53 AM #3
Toyojay's Avatar
Toyojay Toyojay is offline
Real Name: Jay
Toyojay will become famous soon enough
Toyojay's Avatar
Real Name: Jay
Yeah, I'd agree with the above. Difficult to find components to work with the JBL stuff. I originally planned to do the same, and found the weird impedance of the JBL stuff. I wound up replacing everything, all speakers, two amps, sub in factory box but disconnected all JBL. Had to run new wires to the door speakers as well.
Toyota Parts Guy
Looking for a 99-02 Limited AWD to purchase - ideally white or green
2001 Sport Edition - Daily Driver
2009 Sport Edition V6 4WD - Sold
2010 SR5 V6 4WD - Sold
Toyojay is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 01:25 PM #4
Your 2009 couldbe much different than my 04, I found this 2009 limited post,
How to: Replace JBL Subwoofer
Old 02-13-2020, 07:45 PM #5
Real Name: Topher
Real Name: Topher
I should have given more information. I am not keeping the JBL equipment. I've already swapped out the fronts and the headunit.
I need a new amp, would just prefer to know how much space i have to work with so i don't have to remove everything, measure, and then buy an amp.
Old 08-16-2020, 10:30 PM #6
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
I just replaced my sub with an older model Pioneer. It's definitely an upgrade over the stock JBL, but nothing too crazy. I purchased it a few weeks ago for about $100. There are newer subs by Pioneer, Rockford Fosgate, and Kicker that handle more power, but are more expensive.
You said you upgraded your speakers to components. Are they 2 ohm or 4 ohm? Did you replace the rear door speakers as well?
I recommend spending some time on Crutchfield to get an idea of what amp fits. I believe the Kenwood Excelon X802-5 will fit the factory location. It puts out 50 watts RMS x 4 + 300 watts x 1 at 4 ohms. My sub is only rated for 150 watts RMS and i don't want to blow it. Wish I would have thought of that before buying the sub.
I'm likely going to replace the factory JBL amp with a JL Audio JD400/4. Though it's only a 4 channel amp, I plan on running 4 speakers and the sub. I won't have front to rear fade, but I already lost that when replacing the factory headunit. I'll end up with 50 watts to each speaker and 200 watts to my sub.
Here are some resources:
2003 - 2009 Toyota 4runner 4 Channel Amp and Sub Install
How To Wire A 4 Channel Amp To 4 Speakers And A Sub: A Detailed Guide With Diagrams
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 08-17-2020, 06:23 PM #7
Drak's Avatar
Drak Drak is offline
Real Name: Doug
Drak is on a distinguished road
Drak's Avatar
Real Name: Doug
I ran into the exact same question a few weeks ago.
I just bought an entire new system, ground-up, everything.
I was pretty dead-set on mounting the new amp in the same location.
And so I had the exact same question.
I downsized the amp I originally was going to buy based on that exact question.
Which was a $600.00 JL 5 channel amp.
Instead I bought a Soundstream Picasso Nano PN 5.65OD.
It looked like it should fit in the same cavity.
So, I don't have a measurement answer for you.
But that's what my logic and research led me to.
And, in the end, I decided to mount it under the passenger seat just because.
I allowed myself to drop the stubborn idea it had to go in the same place.
I 'moved on' past that hard-stop idea.
But, I think the Nano should fit there, that's why I bought it in the first place.
Crutchfield doesn't have the dimension of the JBL, I called and asked already.
2003 Imperial Jade 4Runner Sport Ed.
Drak is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 12:40 PM #8
riverwolf riverwolf is offline
riverwolf is on a distinguished road
My searches on the topic reveal someone measuring the JBL amp itself at 9"x6"x2". Mounting area is 11"x7.5"x2" according to someone else.
There are a few results where folks have shown the amp they used to replace it. Among those were an Alpine PDR-V75 which measures 10.75"x2"x6.5". The other I found was a Pioneer GM-8604 @ 10-3/8" x 2-3/8" x 7-7/8".
Good luck and let us know what you end up using...and show pictures.
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
riverwolf is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 10:24 PM #9
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
OP where do you have the Kenwood X802-5 mounted now? It seems like it might fit the factory location.
Old 09-21-2020, 04:39 PM #10
Real Name: Topher
Real Name: Topher
I mounted it in the factory location. I did have to trim the cover panel a bit because it did press against it and the entire panel would not fit flush.
Check out my post about the swap out if you haven't already
Factory JBL Amplifier/Sub Replacement
Old 03-02-2021, 12:46 AM #11
Ace5477 Ace5477 is offline
Ace5477 is on a distinguished road
This is exactly what I just ordered. I plan on putting it under the passenger seat. Did you run new wires? Guess the only thing I don’t know is how to run wires under the carpet or under the center console area (if that’s the best route). Or i guess you could run across the back area close to where rear passengers would have their feet. Just curious what you did.
Ace5477 is offline   Reply With QuoteReply With Quote
Old 02-25-2023, 03:42 PM #12
-DOZER-'s Avatar
-DOZER- -DOZER- is offline
-DOZER- is on a distinguished road
-DOZER-'s Avatar
Has anyone considered trying this by-pass harness? MY2016 4Runner is listed in the compatible vehicle list. I’ve also submitted a call back request from PAC to confirm it works.
Speaker Connection Harness - PAC
MY16 Attitude Black 4x4 Limited
-DOZER- is offline   Reply With QuoteReply With Quote
Old 12-06-2023, 03:11 AM #13
Evenimous's Avatar
Evenimous Evenimous is offline
Real Name: Evan
Evenimous is on a distinguished road
Evenimous's Avatar
Real Name: Evan
Question
With the 5 channel amp you chose, do you happen to have your rear tweeters and your front center channel hooked up at all?
I'm looking to replace a blown 5 channel JL Audio HD900/5 that the previous owner installed in mine, and I would like to have all of the speakers properly hooked up. If you've got it in yours, please give some pointers 🙏🙏
Evenimous is offline   Reply With QuoteReply With Quote
Old 03-19-2024, 08:35 AM #14
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
Did you ever figure this out? I just ordered the amp. I don't have the rear tweeters but curious about the front center if you hooked that up?
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
amp , amplifier , factory , jbl , room
Location of factory amplifier? gago1101 5th gen T4Rs 15 08-01-2022 01:02 PM
Help with factory amplifier jrice00 3rd gen T4Rs 8 01-26-2016 01:35 AM
Fs: factory radio and stock amplifier Con10der_8 For Sale: T4R Items 11 02-16-2013 03:00 PM
Factory Amplifier 3rd gen jham For Sale: T4R Items 0 10-19-2011 10:44 AM
'98-'00 Factory Amplifier Dirt4dinner Classifieds - buy & sell (no commercial ads please) 0 01-13-2010 05:13 PM
