Old 02-14-2020, 11:07 PM #1
Bigshankhank Bigshankhank is offline
Real Name: Tyler
Bigshankhank is on a distinguished road
Real Name: Tyler
Lost All Drive Power in 4Hi
Odd little issue this evening. It was raining so I shifted in to 4Hi while waiting at a stop light. Couple little clicks, the 4wd logo went fully green then when the light changed and I pressed the gas I had no power through the transmission and transfer case. In other words, I didn’t move. Shifting back in to 2wd reintroduced forward movement.
Thoughts?
2008 4Runner SR5 V6 4WD
Bigshankhank is offline   Reply With QuoteReply With Quote
Old 02-15-2020, 07:18 AM #2
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
Did you try it again? Could be just stuck. How about doing it while in motion in a straight line?
radlynx is offline   Reply With QuoteReply With Quote
Old 02-15-2020, 10:28 AM #3
Real Name: Tyler
Real Name: Tyler
Did that later on in the drive (switching to 4Hi while in motion), couple clicks then lost all motive power.
Old 02-15-2020, 06:41 PM #4
Robs08Runner's Avatar
Robs08Runner Robs08Runner is offline
Robs08Runner is on a distinguished road
I think its getting hung up. Keep trying to engage 4x4. Be sure you get it's good and hot when you do it.
08 Sr5 4.0 with 5100s at .85 and FJ springs all around.
Robs08Runner is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 02:59 PM #5
Registered User
Registered User
how about switching on the fly while backing up on a straight line. Let us know.
Old 02-18-2020, 03:00 PM #6
Registered User
Registered User
Also, try replacing the front differential oil to remove some metallic particles and try again while in forward motion and backward motion.
Old 02-19-2020, 12:16 PM #7
Andysrt Andysrt is offline
Andysrt is on a distinguished road
We had the same problem. Ours was a broken cv joint. Didn't look broken but when i took it out the insides were destroyed. Once we locked the center diff it would move again while making some nasty noises engaging.
Andysrt is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 01:40 PM #8
Real Name: Tyler
Real Name: Tyler
I'm willing to bet this is closer to the problem, our passenger CV joint boot has been torn for some time and I've bought a new pair of Toyota axles which are still sitting in my garage, but apparently I've waited too long to install them.
Meh, she needs new trans fluid and the shop will flush/fill the transfer case and both diffs for cost of fluid so I'll have them refresh it and if I can convince them to install the new axles I'll just go that route. They've rebuilt a couple transmissions for me over the years and do good work.
Old 02-19-2020, 02:04 PM #9
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
How about 4 Low?
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 07:49 PM #10
JTS197's Avatar
JTS197 JTS197 is offline
JTS197 is on a distinguished road
JTS197's Avatar
Thoughts?
This sounds like a problem similar to mine except mine is AWD (V8). I haven't fixed my 4Runner yet but a few folks seem to think the front differential is the culprit to my problems.
I believe you have an actuator on yours; could it be the actuator not locking the front wheels to the front diff? And then all the power being sent to the wheels with least resistance?
2003 4Runner Limited V8 AWD - XREAS, RAS
JTS197 is offline   Reply With QuoteReply With Quote
4hi , light , power , pressed , transmission
Lost power in Drive - 92 Automatic Tranny HanginInUtah Classic T4Rs 7 02-05-2015 06:51 PM
Help - Lost Power Steering & Power alex19974runner 3rd gen T4Rs 2 02-04-2015 11:18 AM
Lost throttle response after longer drive ChicagoT4R 3rd gen T4Rs 5 09-19-2013 03:58 PM
Hard Drive crashed and I lost all my front coil install bookmarks ryankmasuda 3rd gen T4Rs 5 02-21-2011 11:09 PM
Lost Power 96 SR5 4WD Patrick4R 3rd gen T4Rs 12 01-18-2010 09:24 PM
