Old 02-15-2020, 01:19 AM #1
TannerW's Avatar
TannerW TannerW is offline
Real Name: Tanner
TannerW is on a distinguished road
TannerW's Avatar
Real Name: Tanner
Not sure what to check next...
While driving on the interstate going about 70mph I am having a feeling in the steering that is similar to what a hydroplane feels like. It's not terrible and I'm able to keep it under control but it bothers me. I have had tires replaced due to cupping on the tires and what the tech said was "an alignment from hell" thanks to PepBoys awesome work. I have had rear and front suspension checked and have had both front bearings and CV axles replaced in the past 1,000 miles and both front and rear brakes replaced. I am just not sure what else to check. Could it be tie rods or my whole steering rack going out? Just looking for any input and if anyone else has had these problems. I drive a 2006 V6 with 205,000 miles. Thanks.
1996 V6 SR5 260k
2006 V6 SR5 150k
TannerW is offline   Reply With QuoteReply With Quote
Old 02-15-2020, 07:14 AM #2
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
I would think it's your lower control arm and ball joints.
radlynx is offline   Reply With QuoteReply With Quote
Old 02-15-2020, 05:15 PM #3
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
That and cupped tires are the classic symptoms of shock absorber failure.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 06:32 PM #4
White4runner305 White4runner305 is offline
White4runner305 is on a distinguished road
I have a 2008 4runner and same thing happened at the alignment place. My tires had serious camber and caster issues the tech couldnt fix. My car would be all over the highway. Had it checked by a few mechanics and everything seemed to be fine. Until I went to install a leveling kit and the mechanic said he cant do it because my shocks were completely gone. Gave me a excuse to upgrade to bilstein 5100's. I cant tell you that was the solution just yet. Waiting for them to arrive and I'll install them next weekend.
White4runner305 is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 09:00 PM #5
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
To check shocks and struts push hard on your hood and rear bumper, if car keeps bouncing you need new ones. Might be helpful to try on a known good car so you know what you're looking for if you never have before. If you're feeling something in the steering, which is what I'd suspect from a hydroplaning description, get under the vehicle and have someone turn the wheel back and forth. If you have loose steering you'll see more movement on one side of a steering joint than the other, like if your tie rod is moving but the wheel itself lags behind, you know the tie rod end is bad.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 09:27 PM #6
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
steering rack kit: Amazon.com: 4Runner Tacoma Prado Steering Rack Mount Bushing Kit (95-03) - PSB 401: Automotive
Old 02-16-2020, 09:43 PM #7
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
While the steering rack bushings maybe the OP issue, the kit you posted will not fit his 4th Gen T4R.
2004 Limited V8
Old 02-17-2020, 10:23 AM #8
Jembrmstr's Avatar
Jembrmstr Jembrmstr is offline
Real Name: Jacob
Jembrmstr is on a distinguished road
Jembrmstr's Avatar
Real Name: Jacob
Thumbs up
Sounds like something I was dealing with, eventually replaced control arm ball joints and it fixed it a little, drove it around for about 3 months and the drivers side seal in the rack and pinion blew out. Ps fluid everywhere. Now I’m not saying this is what’s going to happen to you but I’d start with the cheapest thing first and then go from there. It may be a new rack and pinion but your in luck, the 4Runners share the same rack and pinion with the Lexus 470 and prados so it’s not like they are hard to find! One guy does a really good video on YouTube on how to take apart the inner tie rods to DIY the whole job. Just make sure you triple the time you think it will take to do.
2004 SR5 4WD 4.7l, FJ springs w/ 5100's front at 1.75" rear 1.5" poly spacer, led light strip on frame rails w/ dome light mod,FJ wheels, GY duratrac 285's, Smoke LED taillights, Rear bumper light MOD, all new Light housings up front, tint, ventshades, touchscreen Pioneer w/ backup cam
Jembrmstr is offline   Reply With QuoteReply With Quote
check , front , miles , replaced , tires
No need for temp check mode: Eas(ier) ways to check WS transmission fluid level JB. 4th Gen T4Rs 36 11-02-2019 11:48 AM
Check Engine Light, VSC OFF And Check VSC Lights just came on??? the_josh Maintenance/Detailing 5 07-15-2019 01:25 PM
Can anyone run a vin check for me? masphx 3rd gen T4Rs 4 10-29-2016 07:51 PM
Looking at used UCA's. What to check for? jangoforhire 5th gen T4Rs 0 05-26-2012 04:43 PM
check this out #1stunner 4th Gen T4Rs 5 09-28-2005 11:55 AM
