Old 02-16-2020, 05:37 PM #1
nosfanatic2006 nosfanatic2006 is offline
nosfanatic2006 is on a distinguished road
Grinding/whomping
So I've had my 4runner for a few weeks now, no issues. Drove about 150 miles yesterday with nothing weird, then we go to get dinner last night and it sounds like metal grinding metal, but it's rotational kind of like "whomp....whomp....whomp", but I cannot tell if it's up front or in the middle or in the back while in the vehicle.
I tried having the girlfriend drive by me a few times as well as a short safe ride standing on the step and holding onto the roof rack and I cannot hear it outside the vehicle. It adjusts with speed, breaking does not seem to effect it (besides slowing it down), it seems to quiet down a little when turning left but doesn't go away and comes right back once going straight.
I've visually checked everything I can think of, I don't see any signs of anything rubbing anywhere. It's a noise I've never personally experienced and I'm about 90 miles from home where all my tools and my "mechanic" buddies are. I tried recording a video and the sound did not come through.
Any ideas?
2009 Shadow Mica Trail Edition - 2" Dobinson lift, 285/75r16 Cooper ST MAXX, gunmetal FJ Cruiser 16" TRD wheels, 1.25" Spidertrax spacers, Powerstop rotors and pads, Rola roof rack with 4xInnovations low pro mounts and LED's front and rear, NAPA awning, Rago ditch light brackets with Caliraised side shooter led pods, Caliraisedled 2012-15 Tacoma fog light mounts with amber led pods
nosfanatic2006 is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 05:55 PM #2
White4runner305 White4runner305 is offline
White4runner305 is on a distinguished road
Could be wheel bearing?
White4runner305 is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 07:41 PM #3
Real Name: Skip
Real Name: Skip
Any ideas?
From you saying the noise lessens when turning left I would agree that it's most likely a wheel bearing, I would say it's the right front wheel bearing because it's usually the opposite side of the direction you're turning when the noise lessens
I would first get it checked or check it yourself by jacking up the wheel and trying pushing and pulling at the 12 and 6 o'clock position and seeing if there's any play at all, there should be no play at all...another note for the most part wheel bearings don't dramatically fail all at once even after you know for sure it's bad so you can still safely drive on it for some time before replacing it.
2004 Limited V8
Old 02-16-2020, 11:33 PM #4
Nelsoncody Nelsoncody is offline
Nelsoncody is on a distinguished road
I was under the assumption if you turn left and the noise lessens it would be your left because you placed all your load on the right side? Does it do it clearly when turning right? If so that would confirm the left in my understanding.
Sent from my moto g(7) power using Tapatalk
2005 Limited 227K 4.7V8 4WD Daystar 2.5"/1.5" leveling kit, running board delete, stock otherwise
Nelsoncody is offline   Reply With QuoteReply With Quote
Old 02-17-2020, 11:34 AM #5
Had a buddy ride with me who's replaced 3 wheel bearings on his Subaru in the last couple years and he confirmed it sounds like a wheel bearing. Somehow I've avoided this issue with every vehicle I've had so I had no idea. He said he drove for about 8 months after his last bearing started making noise haha. Every rotation makes me cringe so I know I won't let it go that long.
How much does a shop usually charge to do this? Is there a guy who sells the whole assembly that I can just bolt on on the forum? I know there was a guy for the 2nd gen tacoma's when I had my 2013, but wasn't sure if we were that lucky too
Old 02-17-2020, 12:20 PM #6
auto parts stores sell the complete hub assembly to bolt on. i would suggest checking it as mentioned above to confirm it is whats bad before throwing parts at it.
Old 02-17-2020, 01:42 PM #7
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
It could also be a backing plate / dust shield on your brakes rubbing on the rotor (more common after you've had the wheels off and been working on something in that area I'll admit)... use a long screwdriver to push them back and make sure they're not contacting the rotor. I'd give that a look before you start disassembling the hub.
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 02-17-2020, 02:32 PM #8
montijo505's Avatar
montijo505's Avatar
Wheel Bearings & Hubs Press Service *** 4x4 *** PreRunner *** NSK***Koyo*** | Tacoma World
That’s where I got mine. Going on 2 years no problems. The actual assembly installs with 4 bolts. To get it off you will have to remove caliper, rotor, cv axle nut and wheel speed sensor. Takes some time but not a hard job. Easily done with hand tools in a garage/driveway.
Also to confirm. If turning right noise goes away, it’s the left and vice versa. Reason is when the bad bearing gets the load on it it doesn’t make the noise. Good luck!
Old 02-17-2020, 06:01 PM #9
i agree, thats why i said to check it to confirm what the issue is & not throw parts at it. was just letting him know they sell the whole hub at auto stores since he asked about it.
Old 02-18-2020, 08:39 AM #10
Warwicke36's Avatar
Warwicke36's Avatar
Whoops clicked the wrong post to quote. That wasn't directed at you, meant for the OP.
2004 Sport 4.0
back , metal , miles , slowing , vehicle
Speed dependent 'whomping' sound Supermoney 3rd gen T4Rs 1 06-05-2018 08:18 PM
Grinding going from 2wd to 4wd hi Ther00ster 4th Gen T4Rs 5 12-18-2016 01:07 AM
PLEASE HELP, grinding when going into 4L DanielG 5th gen T4Rs 24 11-12-2014 09:27 PM
4Lo grinding Rob_G 5th gen T4Rs 3 04-04-2011 09:22 AM
4h, 4L grinding Bigfootsmurf Classic T4Rs 7 02-11-2011 09:01 AM
