Originally Posted by That_Titanium_4RNR
Thats a great idea about running it without the belt. I will have to try that.
I did a full drain and fill through the lines, not the pan. I need to go back and make sure its got enough fluid though. Maybe I will add little by little and see if any change in the noise occurs. I can always let out if I end up over filling
From what you have described I would say the noise is coming from the transmission, but hopefully it's not.
That being said from what you said in your last post I would say the transmission is low on fluid which will usually make it whine, the reason I think this is because it doesn't sound like you went through the steps/trouble to properly check the fluid level and I'm guessing you just replaced the same amount of fluid that came out during the exchange/replacement, I have read of others doing it this way but if you don't know for sure the fluid level was correct when you started then you don't know it it's correct when you finish and even then I wouldn't trust the level to be correct without going through the proper procedure to verify it's correct.
Modern transmissions are very sensitive to either being low or being over filled even a little bit, either one will have an effect on how it performs, so it very important to check the level properly.
