Old 02-19-2020, 12:37 AM #1
SR502JAI SR502JAI is offline
SR502JAI is on a distinguished road
Torque pro and PIDs for 4th gen 4runners
Good evening T4R.org,
Looking for some wisdom on those of you that know about PIDs and the torque pro App.
Looking to see if there is a PID for the fuel level for the 4th gen 4runner. My fuel gauge isn't working. So i decided to buy a bluetooth obd2 by xtrons (since down the road I will get their android head unit) and get the torque pro app.
I downloaded the custom PIDs provided on the 4th gen forum from a member and some seem to work but the one I'm interested in (Fuel level) is not working. Is this due to me needing to drive and top off and drive again so it can calculate the Fuel Level in adjacent to vehicle info?
Or is their an equation that I need specifically for the 4th gen? The one provided that I downloaded from the 5th gen forum was equation A*500 / 3785.
Any help from those who have been using torque pro app and have knowledge help would be greatly appricated!!!. Thanks in advance!
SR502JAI is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 12:11 AM #2
so im guessing no one uses the torque pro app or knows what PIDs are?
Old 02-20-2020, 12:29 AM #3
UnJeep's Avatar
UnJeep UnJeep is offline
UnJeep is on a distinguished road
UnJeep's Avatar
I use it and use pids for trans temp. It's been a while since I set it up. What is the exact "formula" you are trying? I'll set it up on mine to see if I get a reading. Maybe its not working because the tank sensors are shot?
Sent from my SM-N950U using Tapatalk
2007 Limited 4x4 - UnJeep - AKA "DAS 4RNR"
l Radflo Stage 3 l DO X-Wing Sliders l DO 3 Hoop bumper l Smittybilt Wench l MB TKO Wheels l Nitto Trail Grapplers 35x11.5x17 l Eagle Eye Headlights l Led Fogs l Rigid Light Bar l IPF Spots l RCI Skids l ARB Rear Locker l FJ T-Case swap l
UnJeep is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 09:48 AM #4
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
I think initially the pids were hacked by the Prius crowd. The 3rd gen was released in 2010 along with the 5th Gen T4R and some the 4Runner guys tried and the prius pids worked.
I have not messed with fuel data, but on my 5th gen I was able to read torque converter and pan temps, not so on my 4th gen. No converter temps just the pan temps. The Torque pro app doesn't show that sensor in the 4th gen lineup, and I couldn't find a supporting pid for that sensor.
There was a theory that the 2nd gen prius pids might work on the 4th gen, but I couldn't find anything definitive and no pdfs after a few hours of search. Might be your only option is browsing the forums for the prius or other Toyota models in the 4th gen model year range. Keep us posted and Good Luck!
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 01:57 PM #5
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
I'd like to see the Tranny temp since I tow regularly. I'll do a search to see what comes up but if anyone has any leads, please post up here.
Thank you.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 02:21 PM #6
The "formula" that was produced by the Prius crowd as @4RunnerAquasport had mentioned was A*500 / 3785 which i believe seems maybe a bit too simple? Ive been using the Vehicle Info Fuel remaining display and it works alright but every time i fuel up i have to go back and reset the % to 100, idk why my fuel sensors would be shot, my range reads "correct in the HVAC screen, but my needle will only go half way every single time
Old 02-20-2020, 03:07 PM #7
Gen2 Prius: Custom PIDs for Torque (Android App) with formulas | PriusChat
above is the Link to the Gen II Prius, maybe you can find something i couldnt? I tried looking for the trans temp as well for 4th gen but no luck yet.
Old 02-20-2020, 03:49 PM #8
Real Name: Brett
Real Name: Brett
I do remember finding those pids, but none of them seem to be of any benefit to us.
Old 02-20-2020, 04:56 PM #9
Yeah, going through them i found that none would help with our 4th Gens, i just need some sort of path or gate way so i can come up with the formula, been researching the Prius forum for 2 straight days (even during work...) and no luck.
I wonder if an ultragauge would provide the values...
Old 02-20-2020, 11:45 PM #10
UnJeep's Avatar
UnJeep's Avatar
I'll test that formula this weekend. Although it does look a bit simple. If your HVAC display is working correctly, seems the sensors are ok.
Old 02-24-2020, 01:03 PM #11
UnJeep's Avatar
UnJeep's Avatar
Ok. So this equation is not for fuel level. A = -1. Therefore it returns 500 divided by 3785. Which is .1321... Multipled by -1. You end up with -.1321...
Old 07-10-2020, 09:41 PM #12
04rnr's Avatar
04rnr 04rnr is offline
04rnr is a jewel in the rough 04rnr is a jewel in the rough 04rnr is a jewel in the rough
04rnr's Avatar
Just got this app, got the OBD and paid for the app. WOOOW a little confusing lol.
My compass doesnt work but Ive got another app for that.
Trying to figure out the oil temp. trans temp.
I think the HP, Tq and MPG are working key word there is "think" lol
Any tips?
going wheeling tomorrow so Ill see lol
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
04rnr is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 07:04 PM #13
04rnr's Avatar
04rnr's Avatar
I downloaded this on my tablet, the phone was to small lol..
How the heck to do I get the Engine oil to work? anyone know the PID?
Thanks in advance
2007 Sport.
Old 08-06-2021, 02:09 PM #14
cdoyle's Avatar
cdoyle cdoyle is offline
cdoyle is on a distinguished road
cdoyle's Avatar
Sorry for bumping an older thread, but I'm just now getting into this OBD stuff.
I've been searching all over, but haven't seen a yes/no type of answer if these are available or not for 4th Gens.
Trans Temp?
Oil Temp?
Fuel Level?
Fuel pressure?
If those are available does anyone know the PIDs that work for a 4th Gen?
I cant' seem to get any data on them using the ones from here:
OBD-II PIDs - Wikipedia
Check out my 2004 4Runner Audio upgrade.
cdoyle is offline   Reply With QuoteReply With Quote
4th , fuel , gen , pro , torque
Lug nut torque...what value do YOU use? eddiebx 5th gen T4Rs 103 09-03-2022 08:44 PM
5th Gen Extended PIDs for Torque App JeremyB 5th gen T4Rs 42 07-29-2022 01:58 PM
Impact Gun mid torque vs high torque Bernardchan96 Off Topic 5 03-07-2019 09:37 AM
Which has more TORQUE? MICA4R 4th Gen T4Rs 4 03-15-2012 09:53 PM
Torque or not ?? Camprunner Maintenance/Detailing 4 03-14-2007 07:46 PM
