Old 07-18-2021, 04:58 PM #1
lemii lemii is offline
lemii is on a distinguished road
'08 T4R Front Brake Calipers OEM or Aftermarket?
Thought I would rebuild my front calipers, but on both there is one piston stuck solid...so I'm looking to purchase replacements. I intend to keep the vehicle for perhaps another 10 years, I bought it new and it has 115k miles on it.
So, what's the general consensus (if there is one) OEM $530 for both fronts or aftermarket $180 for both (such as Power Stop)? I do have Power Stop rotors and pads on it.
Please advise.
Thanks.
lemii is offline   Reply With QuoteReply With Quote
Old 07-18-2021, 08:51 PM #2
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Not the most popular opinion, but Im pretty happy with mine from Tennessee. I think they were about $125 each and They have a lifetime warranty on them
Old 07-19-2021, 06:05 AM #3
from Tennessee??? Where exactly did you get them?
Thanks
Old 07-19-2021, 07:49 AM #4
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
Just go aftermarket with a lifetime warranty. Add some paint for extra protection as the aftermarket finished typically rust pretty fast.
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 01:52 PM #5
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
If you're planning on keeping your vehicle and / or you don't want to be replacing them more frequently, go OEM. The biggest thing that fails on aftermarket / rebuilt calipers is the seals. Once the seals fail, it's all downhill and you'll take out your pads and rotors with the calipers.
By using sub-standard parts, the aftermarket calipers are less expensive to manufacture and sell. The lifetime warranty sounds good until you have to use it every year and it doesn't cover the other stuff that gets wiped out.
As Clint Eastwood once said, "So kid, you feeling lucky?"
Too Stroked is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 04:00 PM #6
84ability's Avatar
84ability 84ability is offline
84ability is on a distinguished road
84ability's Avatar
Buy the nice ones from NAPA with the lifetime warranty. I've had to get one replaced and it wasn't too big of a hassle, just hold onto your receipt.
2006 Limited V6 4x4 - Driftwood Pearl - Tacoma/FJ suspension - 5th gen brakes - ATX Mojave Teflons - BFG AT KO - Rockford Fosgate P3SD2-8 sub - Amber fogs - 4500K HID's - Chassis Saver
84ability is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 05:01 PM #7
Of all of the aftermarket parts out there, I would take NAPA over any of them. Especially any "premium" parts that they offer.
Old 07-20-2021, 09:04 AM #8
I bought a set from NAPA yesterday. Now all I need are the new rotors and brake pads...I wll rebuild the rear calipers as they were not fozen.
Then it's just a matter of installing the parts and flushing the brake fluid!
Thanks all
Old 07-20-2021, 08:20 PM #9
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
look into reman toyota calipers. i recently had my rears done. the caliper side was $110 each. remanned by toyota. not sure about the fronts.
make sure if you need the brackets, pins, bushings etc as well. unlike aftermarkets, toyota sells each part individually.
rwh963 is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 08:25 PM #10
Flesh Eater Flesh Eater is offline
Flesh Eater will become famous soon enough
I love the Z36 Power Stop. I have installed them on five vehicles. My one vehicle has towed a trailer from Pennsylvania to South Dakota, did a trip to Colorado, and has towed 8 hours south to WV around 6 times on them. Problem free with frequent maintenance on the slide pins.
Oh and the trailer is around 2,990lbs. and no trailer brakes.
My full size truck is running the Z36 as well and I’ve done a lot of 7,000lbs. towing with it. Zero brake issues.
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 09:18 PM #11
Syr4RinNC's Avatar
Syr4RinNC's Avatar
I meant mavis tires. I was checking google to see if they have mavis tires in Tn
and typed that without thinking apparently
but yea, happy with mine from mavis tires and lifetime warranty
Old 07-21-2021, 07:59 AM #12
I ruined a set of the Z36 Power Stop rotors due to the frozen up calipers. I received the new Z36 rotors and pads yesterday. I bead blasted and painted the rear calipers yesterday and will install new seals etc. today, then begin the install. I'll also flush the brake fluid...any watchouts for that process? I plan to start with the rear passenger side, then rear driver side, then front passenger side, and finish up with the front driver side.
Thanks all.
Old 08-06-2021, 08:26 AM #13
Update:
2008 T4R Limited, V8, 116, 800 miles.
Replaced the front calipers with NAPA remanufactured calipers with lifetime warranty: $188 for both after core charge. Could not rebuild the orignal due to seized pistons in each one. I believe this was the culprit of the rotors warping!
Bead-blasted, painted, and rebuilt rear calipers as I was able to remove the piston from each one.
Replaced Powerstop Rotors (front & back) which were both warped with new Poerstop Rotors and brake pads - Z36 Truck & Tow Kit - $360.77 from AutoAnything.com.
Flushed the original brake fluid, with the help of the wife.
Brakes work great with no hint of any shimmying. Success!
Old 08-06-2021, 08:49 AM #14
S p a r k y's Avatar
S p a r k y S p a r k y is offline
Real Name: Mark
S p a r k y will become famous soon enough
Real Name: Mark
Hate to say this now, You can upgrade to 5th gen calipers that don't have the sticking or freezing problem. Napa ones freeze as well. Had mine for 15 years and have swapped my NAPA's several times due to freezing up. Wish i had done 5th gen. But now that im NAPA, i am staying.
When Napa's freeze, go buy a new napa caliper, swap at home. Then return the napa and they will swap with the warranty. Saves trips to and from.
'04 Sport V8
OME 885's, 1/4" spacers - 5100's at 0 - Toytec Superflexes with 1" rear spacers - 285/70/17 - SCS Gunmetal SR8's - LR UCA's - 20% front - 6000k low's and fogs - LED'd everything- Blacked out head lights - JL Sub and Amp
06 White Tundra - OME 888's and OME Shocks - JBA UCA's - AAL's - Summit Dakar's Black - NRG 285/75/17 - 20% front - LED everything.
S p a r k y is offline   Reply With QuoteReply With Quote
Old 08-06-2021, 09:01 AM #15
Thanks for the advice - should I have to do another brake job due to frozen calipers, I may bite the bullet and do the T5R conversion. I'd have to read up on the details though; I'd rather not have to modify anything on the wheel hubs and such.
aftermarket , front , oem , power , stop
New aftermarket front calipers for those with sticking issues tom4416 4th Gen T4Rs 5 07-26-2020 06:11 PM
Generation 3 front brake calipers/pads/rotors AND New braided front brake lines Capnemo For Sale: T4R Items 0 07-01-2019 01:08 PM
WTB 4th or 5th Gen OEM Front Brake Calipers kcdehart Want to Buy/Trade 0 02-26-2018 10:07 AM
Front Brake Calipers Freezing up on me mitaylor137 Classic T4Rs 5 01-18-2011 01:07 PM
5th gen front brake calipers Jed 5th gen T4Rs 1 03-01-2010 04:52 AM
