Old 02-19-2020, 10:00 PM #1
Nevek08 Nevek08 is offline
Nevek08 is on a distinguished road
Need help making a decision.
Hey fellow 4th gen owners. Doing the Head Gasket next week and I'm on the fence about what else to replace. I used the search and found people with differing opinions. I got a 04 4wd with 164k on the clock.
Should I change the timing chains, tensioners and guides? These parts arent the cheapest so I'm trying to make the right call.
Thanks guys.
Nevek08 is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 07:26 AM #2
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
if your heads are off and your coolant is drained, go ahead and knock the Aisin water pump and water pump gasket kit out. The guides will be a good idea to quiet things down a bit, idk about the tensioners though- i've heard from my local dealer that the timing chain setup doesn't need maintenance.
Maybe also inspect/change your cam bearings, plus get a valve job done while is apart?
Cheers!
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 10:18 AM #3
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Should I change the timing chains, tensioners and guides? These parts aren't the cheapest so I'm trying to make the right call.
Thanks guys.
If it were me and my goal was to keep the vehicle as long as I possibly can I would at least inspect the guides and tensioners for wear (and likely replace them) the chain itself I might leave alone.
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 12:04 PM #4
RivMan's Avatar
RivMan RivMan is offline
RivMan has a spectacular aura about RivMan has a spectacular aura about
RivMan's Avatar
I'm going through the exact same planning. My 06 with 230k miles has the symptoms of a head gasket giving up.
My current plan:
Head gasket kit / replace head bolts
Machine head flat / install new valve seals
Replace water pump
Replace timing chains
Replace tensioners / guides
Replace exhaust studs (Michigan rust, don't trust them to come out clean)
On the fence (aka "While you're in there"):
Install Doug Thorley longtube headers (since they're coming out anyways, getting P0420 already)
Install Y-Pipe (URD or aFe)
-Rob
RivMan is offline   Reply With QuoteReply With Quote
164k , 4wd , chains , change , timing
Making a Decision on Tires uconnapharm Engines / Suspension / Wheels / Tires / Audio / Accessories 0 04-15-2018 08:27 PM
Help making a decision? jay00 3rd gen T4Rs 14 08-27-2016 06:13 PM
Need help making a decision... 5th gen purchase. kennychang 5th gen T4Rs 22 01-12-2015 07:38 PM
T4R decision making m3gumby 4th Gen T4Rs 9 10-25-2008 11:26 PM
Making My Decision In An Hour chunderboy 4th Gen T4Rs 5 12-22-2004 12:49 PM
