Old 02-25-2020, 03:21 PM #16
AE1M AE1M is offline
AE1M is on a distinguished road
Originally Posted by JohnnyxRex View Post
Hey, what do you guys think is the best options for the 03-05 headlights? I’ve sanded down and clear coated my headlights twice at this point - guess I didn’t do a great job, and I’m looking to either fix or swap to something that looks similar to factory on the cheap.
I’m also tired of replacing the bulbs constantly. I’d like to do a HID, HIR, or LED swap. HIRs look particularly easy to swap out, but will they last? Are you using any modern, cheaper HIR/LED options that are still for sale? I’ve found several threads linking to products that don’t exist anymore.
Current headlight condition:
I've tried all kinds of bulbs. I recently purchased the Auxbeam LEDs Low beams (H11) from Amazon $31, the highs (9005) $31 and the Fogs (9006) $56 and will never use anything else. Ripped out all the HID wiring, ballasts, etc..... These are plug/play with OEM connectors. The best. Running all about a year now in MA through snow, heat, etc...
2008 4R Limited Salsa Red Pearl 3Q3
AVS Bugflector,Coastal Lockpick 2,Super Z V1 Radar Detector Mount
Please, no more Hope & Change!
AE1M is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 03:50 PM #17
MSRP. MSRP. is offline
MSRP. is on a distinguished road
Do you have a brand that you prefer? I see Laminx but they want $60 just for the film. Do I just buy a roll of 3M?
I just get a roll off amazon.
Just measure the height of the housing, add 2 inches and measure x2 the width of the housing.
4th gen's are easy to apply with a bit of heat to stretch for curves, and a bit of heat + warm flathead to seal/tuck the edges.
MSRP. is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 01:11 AM #18
JohnnyxRex JohnnyxRex is offline
JohnnyxRex is on a distinguished road
Ok, here's what I decided to do - I'm going to buy a 9012 HIR bulb kit along with a new drill polishing set & 3m film to polish up my headlights this week. If I am unsatisfied, I will go HID and swap the HIRs into my fog lights.
Does anyone have any modern links and cost estimates for a good HID brand? I am looking for the projector included, so I can mount to the OEM or eBay 03-05 headlights. I see old threads with prices under $200, which is doable, but when I go to configure from a reputable brand I always end up $300+.
old threads
Thanks for all the help so far.
JohnnyxRex is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 09:40 AM #19
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
old threads
The Retrofit Source for is the place for all your projector and HID needs. Morimoto is awesome.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 10:41 AM #20
+1
Realistically, they have a lot of B-stock that their/competitor factories push out on other channels for way cheaper (less the obvious Q&A).
Do check out the OEM setup with just a crystal clear lens after polish and film. It makes such a big difference that for the 3 or so years I put off applying the film, I would take 2 minutes before any significant road trip to wipe down with soap and water, throw on my plastic polish of choice (Duragloss plastic polish) + rotary and foam cutting pad to clean up the lens. Took a total of 5 minutes with the proper tools including breaking out the tools to putting them back in the cabinet.
I don't have great eyes, but I'm also not running any fancy bulbs/HIDs/HIR's.
Are you lifted/significantly weighted down with armor? Make sure your headlights are aimed properly too (very easy to adjust on the 4th gen, + aiming guides all over google)
i’m , i’ve , modern , options , swap
headlight bulb upgrade to the brighter more modern bulbs keakar 4th Gen T4Rs 6 09-22-2018 06:21 PM
Trying to sort out headlight/bulb options (2006-2008) Sam Handwich 4th Gen T4Rs 1 04-27-2018 12:35 PM
headlight bulb options 01thunder 3rd gen T4Rs 7 09-22-2016 12:00 AM
Headlight Bulb danpba152 3rd gen T4Rs 12 02-16-2016 11:40 PM
Headlight Bulb owen4runner 4th Gen T4Rs 8 12-28-2005 08:22 AM
