Old 02-21-2020, 02:42 PM #1
Trigle Trigle is offline
Trigle is on a distinguished road
need help! truck wont start
Noob here! This is weird as I just bought my 4r from a lifelong friend whose had it for 12 years. It has 228k on it and runs great BUT. Ive only put 30 miles on it since Ive had it and it sat for a couple weeks after I bought it. Try to start and stone cold dead. I put a mini jump box on it and it barely starts so I decide to buy a battery and it starts right up. Put 5 miles on it, it sat for 2 days and stone dead again. The only light that is on is a red glow from the anti theft icon on the dash and when I turn the key in the ignition and let go something behind the dash makes a tick tock sound for about 30 seconds.
I called my friend who said he would let his ride sit for months at a time and it would never go dead on him. Any ideas?
Trigle is offline   Reply With QuoteReply With Quote
Old 02-21-2020, 03:53 PM #2
Syr4RinNC is on a distinguished road
Sounds like an alternator to me. See if you can get it jumped and take it to an auto parts store to test your battery and alternator. If you're not likely to replace the alternator yourself, you may just want it towed or jump it and drive to a local auto shop to have it evaluated and replaced
Old 02-21-2020, 04:11 PM #3
Elan750's Avatar
Elan750 Elan750 is offline
Elan750 is on a distinguished road
Elan750's Avatar
agreed with above. Usually when you get it started there will be a red battery icon lit up too telling you theres a charging issue.
good time to change the belt too since your taking it off. That said, double check that the belt didnt break...
2005 4Runner Sport 4wd v6 -totaled!
2003 Lexus GX470
Elan750 is offline   Reply With QuoteReply With Quote
Old 02-21-2020, 05:06 PM #4
MikeinNH67 will become famous soon enough
You gotta find out what is drawing the battery down while it's off. There's many youtube videos on parasitic draw. There's a couple that show how to locate the offending circuit doing a drop test across the fuses. Here's an example but there are plenty of others.
YouTube
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 02-21-2020, 05:26 PM #5
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is just really nice That_Titanium_4RNR is just really nice That_Titanium_4RNR is just really nice That_Titanium_4RNR is just really nice That_Titanium_4RNR is just really nice
Real Name: Michael
I hesitate to say its the alt...that being said, you can have the alt tested if you can drive to an auto parts store, or bench test it (involves removing the alt and taking it by itself for testing). Another good way to tell the alt is bad is by turning on dome lights inside the car at night with the truck running and see if they are noticeably flickering. Thats a dead giveaway that the alt is not 100%.
But honestly it sounds more like a parasitic draw issue. There is no reason that after putting in a new fresh battery and only driving 5 mins that it shouldn't start right back up again, regardless if its been sitting for 2 weeks. Even on a very weak alt, you would get at a minimum of like 80 mins run time on a fresh modern battery. Many have reserve times of much higher than that too some over 120 mins. So it doesn't make sense that a 5 min drive would kill it. Your alt may be bad as well, but I don't think that a bad alt would do this all by itself, especially with a fresh battery.
Titanium Metallic 2006 Limited 4WD V8 | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 02-21-2020, 05:45 PM #6
so a fully charged battery can have a parasitic loss to dead due to a bad alternator in only 2 days?
thanks
Old 02-21-2020, 09:50 PM #7
Depends on a lot of things and every situation is unique. Unfortunately, theres never a 100% this is the cause, or that a bad part will cause this problem 100% of the time.
Re-reading your post that you only drove 5 miles after replacing the battery, makes it less likely its the alternator but not impossible. Could be the starter, a bad belt, a short somewhere, or a an abnormal draw of current as noted.
But common things are common.
Old 02-21-2020, 10:37 PM #8
thennen's Avatar
thennen thennen is offline
thennen is just really nice thennen is just really nice thennen is just really nice thennen is just really nice
thennen's Avatar
My sonís 2009 Corolla had a parasitic draw of maybe 150 mA that I eventually traced to an aftermarket remote start that was flaking out. Pulled the fuses on it and the draw stopped.
Alternator wonít cause the battery to go flat just from sitting.
thennen is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 10:39 AM #9
earthrealm earthrealm is offline
earthrealm will become famous soon enough
parasitic draw, use a multimeter to confirm this..its a simple ops. 3mins tops. check the youtube link above
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
dead , friend , put , starts , stone
Truck sometimes wont start...starter contacts? zoombyu86 3rd gen T4Rs 22 04-15-2017 07:45 PM
1997 SR5 4x4 wont let my truck start 4Runnermex 3rd gen T4Rs 14 10-27-2015 10:18 PM
accelerator stopped responding now truck wont even start Woza2003 4th Gen T4Rs 8 07-11-2015 12:33 AM
Truck wont start after brush wire swap rewind206 Classic T4Rs 8 05-19-2013 07:42 PM
Merry Christmas, truck wont start, I think alarm is triggered. HELP! Jon 3rd gen T4Rs 11 12-27-2010 01:44 PM
