Old 02-21-2020, 04:27 PM #1
Rommel's Avatar
Rommel Rommel is offline
Rommel is on a distinguished road
Rommel's Avatar
P0430 pops up 200 miles after resetting the check engine ligths
Hi Everybody,
I went to the mechanic recently and the P0430 has been popping up more. I already changed the 4 Oxygen Sensor, the spark plug, checked the coil and after clearing the CEL, the code would pop up after 200 miles. Is this an indication to change the catalytic converter? I'm in San Jose California by the way and the Toyota in my area has a good online price where I can purchase and pick up. Any help would be grateful. Thanks.
My Divemoblie 4runner
2005 Toyota 4runner V6 SR5
Rommel is offline   Reply With QuoteReply With Quote
Old 02-21-2020, 05:07 PM #2
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Originally Posted by Rommel View Post
Hi Everybody,
Check my recent thread on this subject. For me it was exhaust gaskets. Cheers
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 02-21-2020, 07:58 PM #3
newton22 newton22 is offline
newton22 will become famous soon enough
Did you use Denso sensors? If there are no exhaust leaks (gaskets replaced), all 4 sensors, no vacuum leaks then it might just be the cat. Only the cats on the headers are monitored.
2004 SR5 4WD | 5100s | Level 8 MK6s
newton22 is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 04:30 PM #4
4Runnin2MRG 4Runnin2MRG is offline
4Runnin2MRG is on a distinguished road
Hi Everybody,
I had the same code pop up for me, I had to replace the catalytic converter. I also recommend going with OEM cats, aftermarket ones have a tendency to crack.
4Runnin2MRG is offline   Reply With QuoteReply With Quote
Old 02-23-2020, 07:48 PM #5
2003-4x4runner's Avatar
2003-4x4runner 2003-4x4runner is offline
2003-4x4runner will become famous soon enough
I had the same issue and ended up replacing the drivers side CAT PO430. I was told their was only one California Approved CAT available at the time for the 4Runner. New CAT and labor was $1000.
You should check the gaskets after the CAT to see if they are bad just to confirm its not the gasket.
2003 V6 BLACK SR5 4X4-Runner
OB #1334
https://www.instagram.com/ob_1334/?hl=en
Dad's Travel Service.
We drive around till we find it. No map's needed!
2003-4x4runner is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 12:57 AM #6
Rommel's Avatar
Rommel's Avatar
Yeah I checked it and unfortunately it seems the catalytic has died. The Steven Creek Toyota Parts people said we can order the CAT on their website and go pick it up. The price was like $493.10 so I'll probably be doing that since I intend to drive that vehicle for a long time.
Old 02-24-2020, 06:37 AM #7
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Scotty Kilmer (TV mechanic with 50 years experience) says if it runs right with all the sensors flashing - just ignore them and keep on truckin. BUT. I'd check the oil level.
2005 V6 4runner with 150,000 miles and I haven't had 1 idiot light come on since I owned it (15 years).
No rust anywhere on body - but superficial rust underneith. OMG!
SUV starts on first crank all the time. Rides great. Fast for a V6!
Change the oil and filter myself every 4000 miles - right in my driveway (gated communiity in Nassau Bahamas). Dino only. 4 Starters in 15 years. 4runner goes through them like free pizzas!
Had dealer change the transmission fluid (5 quarts) at 100,000 miles (holds 12 quarts)..
4runner is in Nassau Bahamas where it's 90 degrees to 60 degrees all year long. No body rust and I am 2 blocks from the ocean.
I could buy a brand new one, but why would I do something so stupid? Brakes were done once. 4 tires once.
Captsolo is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 11:34 AM #8
Mantilgh Mantilgh is offline
Mantilgh will become famous soon enough
Cheap potential P0420 P0430 Catalyic Converter Efficiency Fix
Or just throw a cat at it.
Do cats really go bad without something being majorly wrong with the engine?
I believe exhaust leaks are the main reasons for the codes, not the cats themselves
Mantilgh is offline   Reply With QuoteReply With Quote
Old 03-16-2020, 12:17 AM #9
Rommel's Avatar
Rommel's Avatar
Changed the converter today, prices weren't bad which I bought at Steven's Creek Toyota and they had the parts ready. Took the whole day job and I was going to film it for youtube but camera died. I'll post later on when the vehicle reaches 200 miles and see what happens.
Old 03-16-2020, 09:42 AM #10
sonicc sonicc is offline
sonicc is on a distinguished road
They can crack from years of heat cycling.
sonicc is offline   Reply With QuoteReply With Quote
Old 04-16-2020, 12:23 AM #11
Rommel's Avatar
Rommel's Avatar
Okay, 1,500 miles later, looks like the P0430 code isn't popping up yet. I checked both gasket on the front and the end of the manifold/catalyatic converter so looks like this issue has been resolved. Hopefully the vehicle will continue up to 300,000 miles.
Old 04-16-2020, 04:36 PM #12
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
mine only comes up on highway trips, p0430 and p0420, how easy was the exhaust manifold gasket change?.
any gotcha??
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 04-16-2020, 06:24 PM #13
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Yes, over time they become less efficient. The ECU can compare the readings between the upstream and downstream O2 sensors and tell when the cats are no longer doing their job, (removing pollutants). When that happens it will turn on the check engine light.
importman is offline   Reply With QuoteReply With Quote
Old 04-25-2020, 11:20 PM #14
Rommel's Avatar
Rommel's Avatar
any gotcha??
Which end though? The one at the engine block or the other side?
Old 04-26-2020, 10:24 AM #15
the ones you need to disassemble to tackle the p0430 and p0420 CAT error codes
catalytic , change , miles , p0430 , toyota
08 v6 check engine code P0430 cangler Problems & Warranty Issues 12 05-06-2018 03:58 PM
ANOTHER p0430 question: V8 2uzfe, 200k miles timing belt explosion Streetfighter 4th Gen T4Rs 3 06-20-2017 02:38 PM
Check Engine Light:Issues p050b p0420 p0430 liqourish 4th Gen T4Rs 1 06-14-2017 12:46 PM
TC002R-03 12/21/2004 Engine/Transmission Controls - Resetting ECM Memory CBR_GUY_IA TSB 0 07-12-2009 10:17 PM
resetting engine light, gas cap off msanta Problems & Warranty Issues 3 06-26-2008 02:40 PM
