I did both of mine: passenger side and driver side. I didn’t remove the headlight for either as I recall, although I thought I might have to. I was able to get to the passenger side okay since I have small hands, but the driver side was a *****.
I found a YouTube video which showed moving the battery—I don’t recall that I removed it, perhaps I did—and the using a 17mm socket (I think) with an extension to place over the base (after unplugging the power plug) and twisting it out. I then used a set of long needle nose pliers to reach in and retrieve the lamp base.
Sorry if this isn’t maybe very clear since I did this a couple of years ago, spending an hour or more scratching my head, searching online and swearing liberally.
