05-04-2020, 02:51 PM
#31
Originally Posted by chaincleaner
Well in my defense the bumper does look pretty slick in that particular photo!! Haha. I was like, why did you get a new bumper?? I may end up with a steel bumper in the front and rear in the future also, which makes choosing the suspension set up now a bit more difficult, since I’m not sure. Who did you go with for the bumper? I think I might go with 4x4labs if I ever do it, possibly their diy weld together kit, great price. And maybe add their swing away bike rack. So many nice fabricators out there though.
Thanks, they do look pretty good! Haven’t tried aiming much yet as I haven’t gotten out at night other than to find a spot to aim my hid lo beams. Not really sure how I should aim the fogs and a YouTube search didn’t immediately yield much helpful info. I figure they should aim slightly downward of course. Any tips?
hahahahahhaha! It looks good in most photos - I guess it's just the white. I wouldn't fret too much on suspension choice - most fo the time if you do end up adding so much weight that it sags, there are longer/stiffer springs to swap out. The one I ordered is only ~90lbs so I doubt I'll see any actual sag for a bit. I went with True North's Hybrid Bumper for the front and am going to get a local fabricator to make me a rear tube bumper with a swingout (and probably skids) - trying to keep it relatively light. I'll probably end up with a second set of pods since that bumper has provisions for 4!
When you aim you low beams, just aim the fogs under them. I got the fogs to fill in the lower area the low beams don't cover.
[IMG] [/IMG]
Something like this would work and then go out to a wall to verify they don't point too far upwards and cover as much as you can below the low beams.
2006 4Runner Sport Edition V8 4WD
05-05-2020, 12:55 AM
#32
Originally Posted by Drift Monkey
Honestly, I was researching and such and found these before the TW thread, although I will say, the testing there really sealed the deal! It looks like Lightwerkz has them in stock with free shipping if you're really itching - I ordered from them and they came pretty quick. They're still one of my favorite mods!
I don't think I would have done anything differently - except maybe order the DT connectors you linked directly from DD. The Amazon ones worked fine but the DT connector heads were a real PITA to get off in order to reverse the polarity - as I said I ended up using the included DD DT connectors on the pigtails and they were a breeze to remove.
Super easy to aim, I just tightened the mounts a decent amount to where they are firm but still able to be moved and it's been working great like that - they haven't dropped or anything while driving/hitting bumps/off-road stuff/etc.
The angled models might work better in our pockets (I considered about it as well), but I can't confirm - everyone who I consulted about trying this suggested the basic round models. They might still leave a gap so you'd still probably have to paint the inside of the pockets, but they'd fill in more of the space. I plan on getting a steel bumper at some point so I figured having the "universal" round models would work better when the time came to mount 'em elsewhere. If you plan on keeping your stock bumper - it might be worth a try!
If you keep an eye out, Lightwerkz often runs 15% off promos on DD products from time to time (with free shipping) to soften the blow. It's crazy that these are "budget friendly," but considering the competition's prices
you're right, they are gthe best value for the price - I'm very impressed with the overall build quality/output. The Pro models might have been nice, since my retro'd headlights are super intense, but after using the Sports in very foggy conditions somewhat recently, these did a great job. I don't regret not going Pro, personally - it would have been purely for aesthetics. The Sport's pattern/cutoff/width are great - good throw and SO WIDE - wider than my headlights even. I don't think you'll regret 'em.
Hey there which exact DT connectors would you get from DD.. sorry I see they have a few. And I’m kinda lost.. thanks a lot !
05-05-2020, 05:40 AM
#33
DT to 9006
I think
@ chaincleaner
used those exact ones - not sure if he had to reverse the polarity on the DT. Probably not since it came straight from DD.
05-07-2020, 09:56 AM
#34
I installed my fog lamps the other day, I know with them being mounted to the plastic bumper it's going to move and flex but everytime I go over a bump the light will move/shake which is driving me nuts.
Anyone else having this issue?
2006 V8 4Runner Limited
FOX 2.5 DSC | Total Chaos | Dobinson 677V | Doug Thorley Headers & Y-pipe | Gibson | RCI Metalworks | BudBuilt | SCS Ray 10 | Wildpeaks 285/75/17 - 34s
Instagram @ TXT4R
05-07-2020, 01:43 PM
#35
Mine have never moved out of place. Did you tighten the 2 screws that’s attach the brackets to the pods?
05-07-2020, 04:06 PM
#36
I'm really digging it... I went to their site wanting to get a small yellow light bar but it looks like they use a different color lens.
It's way more amber than the SAE/DOT Yellow units which are more pleasing to my eye.
I just don't want a round housing. I might just have to bite the bullet and go with Baja Designs but wanted to try these guys out. They look like they make decent stuff.
05-07-2020, 04:50 PM
#37
Thanks bro! Yeah, they use amber for their light bar lineup - should be an easy fix to make it yellow with some Metalcast yellow spray paint (I used their amber on my corners inside the headlight housing and it turned out pretty great) - at least that's my plan once I get around to getting a light bar someday.
DD makes different bezels for the SS3 lineup maybe give those a shot if you hate the round?
The difference between Baja and DD seems to be that SS3s actually give a brighter output while maintaining a nice sharp cutoff without any bleed, a well known issue for the Squadrons - also they have a wider pattern.
Check this out for more comparisons: The LED SAE J583 Fog Pod & Fog Light Review | Page 137 | Tacoma World
Even the selective yellow Sports out do the Baja/Rigid SAE offerings - much less the Pros lol - all for about $100+ less to boot.
05-07-2020, 05:52 PM
#38
@ Drift Monkey
I am not really interested in the SAE/DOT rating... i'm wanting to put this on my ATV (Raptor 700) in the front bumper as a primary drive light in the desert at night.
The yellow makes a massive difference in contrast in the sand as it doesn't blow out the highlights up close... and in dust conditions when compared to a bright white light.
I actually want the flood/spill, but want a separate housing so I can aim it differently than my fixed headlights which are 35 watt yellow HID.
05-08-2020, 02:46 AM
#39
@ Drift Monkey
Well, either way - I wouldn't count DD out lol - their other optics are equally impressive what what I've seen. I love yellow lights haha.
05-08-2020, 01:04 PM
#40
That is true... and it's good to have more options on the market. There was a lack of SAE/DOT options and at more competitive prices.
BD and PIAA had a lock on the market and they were both really expensive.
I'm surprised the PIAA RF series light-bar isn't more popular, I really like them, but I think it's probably the cost that drive people away.
PIAA | Yellow RF Series Lights Auto
05-09-2020, 06:36 PM
#41
Real Name: Ed
Real Name: Ed
So lightwerkz has the vehicle specific kits in stock, but the universal kit ships from DD, like you said. I called and got AMAZING customer service from Brendan.
Lightwerkz trivia: Brandon owns a FJ
05-10-2020, 11:08 PM
#42
Instagram @ TXT4R
05-10-2020, 11:39 PM
#43
Lookin' SHARP my dude!
05-10-2020, 11:50 PM
#44
Thanks and thank you for doing this how to, it pushed me to finally pull the trigger.
Instagram @ TXT4R
05-11-2020, 12:10 AM
#45
Always glad to help a fellow Houstonian!
