12-15-2020, 02:59 PM
#76
Originally Posted by Drift Monkey
Forgot to update this thread when I switched over to my steel bumper, but I added a second set today so I figured y'all might wanna see.
Nice bumper! what company is that from? been looking for a hybrid style bumper
12-15-2020, 10:09 PM
#77
True North Fabrication
2006 4Runner Sport Edition V8 4WD
12-16-2020, 12:40 AM
#78
Originally Posted by Enigma8246
Are these the model sold for 5th Gen 4Runners?
No these are the universal ones that comes with the standard bracket. All I did was drilled a hole on the bottom portion of the bumper as the op did. So far has held up fine and sturdy.
Current - 21 TRD ORP, Method 316 on 285/75/17 Toyo MT, Bilstein 5100’s OME 885/889, Spc UCA
Old(still in the family) - 07 Sr5 V6 2wd, Bilstein 5100's, Ome 884/895e, TRD ORP wheels, SPC UCA and CBI front skid plate.
03-27-2021, 04:50 PM
#79
I plan to put in a smaller steel bumper that leaves the portion with the fogs intact, so I went ahead and purchased the angled model. Pics attached here for anyone that is trying to decide between the standard and angled ones.
Thanks
@ Drift Monkey
for the inspiration! Super pleased with the final result.
06-20-2021, 03:02 AM
#80
Finally jumped on buying some of these. After seeing the angled front on some of the other installs I was sold. I wasn’t sure how well the single bolt through the bottom would combat any shaking while driving, I wanted something a little more sturdy. So I used the Type F2 mount from DD. I drilled a second hole behind where the original bolt went in. I put a bolt and lock washer in each side. Between the hardware and the front trim piece the lights are not going anywhere. Also with the mount I chose I did not have to paint behind the light.
Somehow I received Pro model lights when I ordered Sport model. The small brown box indicated it was Sport but the sticker on the bottom of the light itself says Pro. If I am mistaken please correct me.
Thanks to
@ Drift Monkey
for the thread and to all the others who have done this mod for sharing their installs.
2006 GGM Sport 4WD / Lots of maintenance from neglect (from previous owner) / Interior & Exterior LED swap / Sony XAV-AX1000, Kicker front door speakers, Kenwood tweeter replacement / Diode Dynamics SS3 Fogs
Reason: Incorrect mount info previously
06-22-2021, 10:23 AM
#81
Real Name: Blake
Real Name: Blake
Thanks for the write up
@ Drift Monkey
, I definitely will add this to my overall headlight retrofit.
22 SR5 Prem 4X4- Magnetic Gray
07 V8 Limited 4X4 - Natural White (SOLD)--> "Moby Dick" Build Thread
03-12-2022, 03:35 AM
#82
Thanks to
@ Drift Monkey
Thank you so much for this write up and your advice! I asked my shop to replicate and it turned out absolutely amazing! Check out the video they made:
4th Gen 4Runner - G5-BRT Projector Retrofit + SS3 Max Fog Lights - YouTube
03-13-2022, 07:07 AM
#83
@ dsanford
@ fayraree
i just put in my order from lightwerkz , going to try do what you guys have done and jump on the led fog light band wagon.
still not sure if i want to buy some yellow covers too.
my current setup is stock fogs with amber film, also have 3000k hid bulbs, output is deep color, no glare.
i have tried using 3000k with no film, its yellow with some glare.
4300k with amber film was identical to 3000k no film.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
03-13-2022, 01:55 PM
#84
Real Name: Ed
Real Name: Ed
Originally Posted by fayraree
Small world! OP bought his retrofit and Diode Dynamics parts from Lightwerkz Are those "Akkon" headlights?
03-19-2022, 03:35 AM
#85
Yup, Akkon from Amazon!
03-20-2022, 02:04 PM
#86
Originally Posted by riceandpho
@ dsanford
@ fayraree
Buy the yellows from DD. It's a warmer temp LED behind a 3K lens. Putting a yellow cover or lens over the standard white model 6000k SS3 won't result in a deep enough yellow.
03-21-2022, 12:55 AM
#87
just waiting for my package to come, was thinking about the amber or yellow covers to add on.
04-03-2022, 03:55 AM
#88
04-04-2022, 06:01 AM
#89
more pictures since each post can be max of eight. the bigger washer should stop the mounting tabs from popping out. i know one of my tabs was flimsy so this should work better. so secured. if i take the covers off the light is more yellow, covers on and its more amber.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
