02-23-2020, 05:33 PM
Got the Gooey Rear Hatch Button Cover Replaced
Finally had a couple warm days and some free time up here in Minnesota. After some cursing, wailing and gnashing of teeth I got the old screws out and cleaned all the black goo from the rear hatch button on my 4Runner. I resorted to electrical contact cleaner to get the plastics around the switch cleaned up but now I can open the hatch even when it's -20 outside (at least I hope I'll be able too)...
The dealer gave me an estimate of $200 for the job - got the part on Amazon for $12
Given this is a cheap common part available on Amazon I have to believe this is a common problem. It doesn't appear Toyota has laid claim to it though.
02-27-2020, 08:25 AM
Any chance you could share link to part?
02-27-2020, 08:47 AM
Real Name: Newell
Real Name: Newell
+1 for the link.
I'm due to replace mine since the rubber is melted/sliding off. Still opens fine in the extreme cold though.
02-27-2020, 10:25 AM
+2 for the part link! Mine is kind of falling apart, and for that price I'd love to fix it.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
02-28-2020, 09:50 AM
This was literally the first thing I did when I got my truck. Best $12 I ever spent
03-01-2020, 03:37 AM
I did the same last week. What a difference! However, if I could make a suggestion, I would recommend to replace the entire switch, not just the rubber pad. You're removing it anyway. While I was spending time cleaning off all of the melted rubber, I wish I had just gotten a whole new one and would've been done in 1/2 the time. Do a search for Dorman 901-725. I'm not sure if that is the OEM or aftermarket. Various sites have it anywhere from $40-$55.
'07 V8 4wd Limited, '20 BMW M340i (on order for Euro Delivery), '19 MB GLS450, '17 BMW 340i, rwd, 6MT, M-Performance Power & Sound Kit, H&R springs
Prior: '14 BMW 320i, '16 MB GLE350, '06 LR LR3 HSE, '12 MB ML350 diesel, '11 Accord 5MT, '08 Accord 5MT, '06 Xterra 6MT, '98 BMW 528i, '95 Mazda Millenia
03-01-2020, 11:04 PM
have to agree with this guy a little, i did the rubber only replacement and that was messy, if i had to do it all over, i pay the extra for the new oem assembly, no mess and no fuss.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
03-02-2020, 01:00 PM
I cut a piece of thin rubber it stuck to the mess and covers it, works great when pressing on it.
Update I also used heavy foil tape over the rubber this really kept it covered and so far I can open it with no black junk on fingers.
03-02-2020, 01:23 PM
Replaced the hatch button cover over the weekend, and definitely would have saved a ton of time by replacing the entire switch. Tools and hands covered in the black rubbery goo. Cleans ok with Lysol wipes though.
_______________________
Nautical Blue 2007 SR5 V6 4x4. Bilstein 5100's all around, front at 0.85", Metallic Grey TRD Pro Wheels.
03-06-2020, 02:06 AM
Sorry for the late reply folks... yes, the link provided by Berty_K is what I got from Amazon. I don't have much spare money so it was worth the 20 minutes I spent cleaning up the old switch.
In my case with Minnesota's cold weather under about 25 degrees F the gooey rubber froze and I couldn't get the hatch to open at all so just putting a new layer of rubber over it wasn't an option.
03-17-2020, 05:03 PM
Just did this on Saturday. You're lucky that it only took you 20 min. It took me over an hour to get all that gooey black mess cleaned up! Night and day improvement though and happy with the result!
11-12-2022, 12:47 PM
Did the rear hatch switch on my 2008 today, found this thread helpful.
OEM part available on Amazon for $40, also picked up a cheap set of door panel trim removal tools for another $5.
Several videos on YouTube of this job being done, my 4Runner has been garaged since day one and I still broke a couple of clips on the emblem trim piece (one of the tabs that hold the lock and the top-most body clip).
Easy job, time was about a beer.
Not Stock 2008 V8 4WD SR5
11-21-2022, 10:05 AM
Great find. For $30, I will replace the whole switch.
2008 SR5 V6 4x4
11-23-2022, 11:47 PM
Post removed.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
