Old 02-24-2020, 09:54 AM #1
benztech82's Avatar
benztech82 benztech82 is offline
benztech82 will become famous soon enough
benztech82's Avatar
Pulling to the right when 4x4 engaged under acceleration
Hey guys,
I got a weird issue which became more noticeable after i did a lift.
Truck is pulling really hard to the right when i hit gas pedal. No issues when coasting, braking or when i'm in rear wheel drive mode. I have new lower control arms, links, balljoints are all good, new front wheel bearings and tires are coopers st maxx with 20k on them. Both front driveshafts replaced 40k ago.
Sent from my Redmi 4 using Tapatalk
benztech82 is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 10:47 AM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Sounds like the axle isn't fully engaging then. Get the wheels off the ground with the truck in 4wd and turn the front wheels by hand and see if they both turn.
The right axle is the one with the disconnect so it seems odd it's pulling to the right. But it sounds like something in the front diff or the axles somewhere. Tcase sounds like it's working just fine since you are getting power to one of the wheels at least.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 01:38 PM #3
codeman528 codeman528 is offline
codeman528 is on a distinguished road
I had a very similar issue a while back! Thought maybe it was my rear control arms so I replaced all 4 and it got a little better, but not solved. Ended up getting my wheels and tires balanced and then rotated because I was was having a vibration issue, and that resolved it for me I was boggled but happy the problem was gone. Might be worth a shot!
2005 V8 Sport Edition 4WD | Bilstein 5100 | OME 885 and 895 | TRD Pro Wheels | 265/70/17 Falken Wildpeak AT3s | USA Spec Bluetooth Audio | Rago Fabrication Molle Panel | Victory 4x4 Front and Rear Bumpers | BajaDesigns Squadron Sport Ditch Lights | Morimoto HID Retrofit
codeman528 is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 03:40 PM #4
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
Yes.
This happens by design. It is called the "Thrust Angle" and is built into truck from the factory. The rear diagonal control arm (panhard bar) is designed to minimize the thrust angle changes under acceleration by describing an arc close to zero degrees under acceleration as the truck pitches rearward. Lifting the truck causes the arm to describe an arc with a negative value that moves the axle to the driver side under acceleration and back to the passenger side when driving straight. Aligning the truck to factory specs cannot accommodate for the changes in rear suspension geometry when under load. Thus the alignment is wrong under acceleration and correct when traveling under low engine load scenarios. The higher you lift the rear of the truck, the worse it gets.
You can get panhard mount weld-on extensions.
I think a better solution would be to install a fully parallel 4 bar linkage that uses the existing mount and does not involve any weldling.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 07:44 PM #5
benztech82's Avatar
benztech82's Avatar
Originally Posted by duffdog View Post
Yes.
Um...alignment fixed it today.
Old 02-25-2020, 06:19 PM #6
Ok. Your truck must not have much of a rear lift.
2005 Blue SR5 v8
Old 03-18-2020, 11:46 PM #7
benztech82's Avatar
benztech82's Avatar
Probably not, 1.5" daystar with 2.5" OME spring and 5100.
front , lower , pulling , tires , wheel
Loss of 4WD after it is engaged FrontRange4Runner 5th gen T4Rs 16 12-19-2015 01:58 PM
pulling to the right on acceleration in 2wd mcintyre12 3rd gen T4Rs 3 05-09-2015 12:01 AM
Help! 99 4x4 "engaged light" is on when not engaged! Hunter Green 3rd gen T4Rs 2 07-30-2010 11:47 PM
Parking brake engaged and acceleration CardsFan Problems & Warranty Issues 15 02-28-2007 06:53 PM
