Old 02-24-2020, 08:08 PM #1
Hunter.Cribb's Avatar
Hunter.Cribb Hunter.Cribb is offline
Real Name: Hunter
Hunter.Cribb is on a distinguished road
Real Name: Hunter
Water pouring in when I open the rear hatch!
Does anyone else on a rainy day have water dump into the back when they open their rear hatch?? The weather stripping seems to be In good shape but water does not escape to the sides it just pours over the lip. Has anyone fixed this by replacing the stripping?
2006 Limited V6 4WD, Natural White (Sold)
2006 Limited V8 4WD, Salsa Red Pearl
Hunter.Cribb is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 08:25 PM #2
MikeinNH67's Avatar
MikeinNH67's Avatar
There's vent holes in the bottom of the hatch door (black plastic I think). They get clogged after awhile. Use something thin to clean them out or take the inner panel off and clean the debris from the inside. Also make sure the weather stripping is all intact, there should be a horizontal piece that pushes against the rear window. Often it falls off allowing lots of water in, no matter what some gets in on the left & right edges but should be minimal. Below is the replacement piece if needed.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Search here for the part number listed in the Amazon link and you'll find plenty of threads like the one below.
Rear window seal, repair or replace ?
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 02-25-2020, 12:13 AM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Originally Posted by Hunter.Cribb View Post
Does anyone else on a rainy have water dump into the back when they open their rear hatch?? The weather stripping seems to be In good shape but water does not escape to the sides it just pours over the lip. Has anyone fixed this by replacing the stripping?
Sounds like you have something blocking the water from draining to the right and left when the hatch is closed, check all the weathering stripping on the hatch and body and make sure they're not loose and creating a dam.
2004 Limited V8
Old 02-25-2020, 08:29 AM #4
Real Name: Hunter
Real Name: Hunter
Thanks for the replies. I will check the weather stripping and drain holes to see if it’s clogged.
Old 02-25-2020, 11:24 AM #5
rodsrunner rodsrunner is offline
rodsrunner is on a distinguished road
I had the same problem, removed the 2 bottom plugs and left them out, problem solved.
rodsrunner is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 12:04 PM #6
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
yep. same thing happened to me. I pulled those 2 plugs, it has been fine since.
if there are other regular drain holes, I don't remember seeing them...
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 07:27 PM #7
Real Name: Skip
Real Name: Skip
I could be wrong but I think ya'll are misunderstanding what @Hunter.Cribb issue is, I don't think the water is coming out of the hatch when he opens it, but instead when he opens the hatch when it's raining the water coming off the top of his T4R goes up over the rubber gasket that is attached to the body above the hatch opening.
I have a somewhat similar issue because I have numerous large trees in my yard and leaves are always stuck and built up behind that rubber gasket if I haven't opened the hatch for a while, causing a similar waterfall affect if I haven't cleaned them out so when it's raining hard and I open the hatch I get a little bit of water coming up and over the gasket, as long as I removed the leaves recently I don't have that issue.
2004 Limited V8
Old 02-25-2020, 08:08 PM #8
Real Name: Hunter
Real Name: Hunter
Yes that’s exactly what’s happening. I cleaned everything up really good. We will see if I have anymore problems when it rains again.
Old 02-25-2020, 08:48 PM #9
MikeinNH67's Avatar
MikeinNH67's Avatar
Ah, then no...lol. Mine used to poor water out of everywhere it could but mainly the latch mechanism. Tell us how it goes.
Mike
03 4runner Limited
Old 11-10-2020, 09:39 PM #10
isu2dc2mke isu2dc2mke is offline
isu2dc2mke is on a distinguished road
has anyone seen leak this near the top seal of the tailgate?
isu2dc2mke is offline   Reply With QuoteReply With Quote
hatch , open , rear , stripping , water
Rear hatch won't open. Jasonredwood 4th Gen T4Rs 67 06-12-2023 02:42 PM
AC is pouring water in the car as we drive. T4RT 5th gen T4Rs 7 07-15-2017 11:15 AM
No way to open rear hatch with key? MeBe4running 5th gen T4Rs 24 10-22-2012 10:35 PM
Rear Hatch Won't Open.. Ameritimer Problems & Warranty Issues 0 04-12-2011 08:50 PM
03 rear hatch won't open! mxnmtber Problems & Warranty Issues 4 10-04-2006 08:54 AM
