Old 02-28-2020, 04:57 PM #16
Monty87ls Monty87ls is offline
Monty87ls is on a distinguished road
Also budget?
Monty87ls is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 11:10 PM #17
chocker chocker is offline
chocker is on a distinguished road
I haven't gotten the sub yet. It will depend if im getting a 2 or 4 ohms amp. I really don't need anything crazy as this is just an 8" subwoofer. I just want to fill out the sound. I know it's not going vibrate the truck.
chocker is offline   Reply With QuoteReply With Quote
Old 02-29-2020, 09:58 AM #18
Hi, i haven't chosen a sub yet. I am waiting on what I'm going to get in terms of amp for 2 or 4 ohms. It's only an 8 " sub so im not expecting earth shattering sounds but i want to fill out the sound.
Old 02-29-2020, 11:06 AM #19
Just what I would do if I was only doing a mono amp and sub I think. The first 2 subs should fit i believe and the third is a shallow mount so def will fit.
AMP
Kicker 46CXA400.1T CX Series mono subwoofer amplifier — 400 watts RMS x 1 at 1 ohm at Crutchfield
SUB
Kicker 44CWCD84 CompC Series 8" subwoofer with dual 4-ohm voice coils at Crutchfield
Kicker CompR 43CWR84 CompR Series 8" subwoofer with dual 4-ohm voice coils at Crutchfield
Kicker CompRT 43CWRT81 CompRT shallow-mount 8" subwoofer with dual 1-ohm voice coils at Crutchfield
Old 02-29-2020, 11:09 AM #20
150 watts should be fine but if you wanna bump it up to 300 just get the 2 ohm version of those subs.
Old 02-29-2020, 06:41 PM #21
Thanks so much for the information. I was looking at a used Alpine MRD-M300 for 50$ CAD in great shape but since you gave me these options, i might just wait a bit and pay more for better matching equipment.
Old 03-01-2020, 01:39 AM #22
Hey if it works might worth picking up and could still use it with one of those subs. Ive never had a ticket myself but heard good things. Im between getting Kicker or JL audio myself but Ill be using a 5 channel amp since doing the speakers also.
Old 03-02-2020, 03:26 PM #23
I went for it. I ordered
Kicker 46CXA400.1T amp
Kicker CompRT 43CWRT81 sub
Im going to run the sub dual voice coils in series to get 2ohms. Also the amp is a better fit for the enclosure. Can i just screw it into the plastic as i know the mounting holes with definitely not line up.
Old 03-23-2020, 01:29 PM #24
cbailey1523 cbailey1523 is offline
cbailey1523 is on a distinguished road
Hey I haven't been in there to look at it yet, but do you all think that with a little massaging and fabrication a 10" Sub would go into the enclosure?
Sent from my SM-G975U using Tapatalk
cbailey1523 is offline   Reply With QuoteReply With Quote
Old 03-24-2020, 04:19 PM #25
No answer at all? That's unusual.
Old 03-24-2020, 05:48 PM #26
Real Name: Skip
Real Name: Skip
WOW, you need to have a little patience and give those who maybe able to answer your question time to even see your post. it's only been a little over 24 hours since you posted and not every member here can answer your question, also these are trying times with what all is happening in the world and this country and many members are most likely not visiting the forum since many have had their normal day to day life turned upside down if not worst!
2004 Limited V8
Old 03-25-2020, 01:35 PM #27
rokr1292 rokr1292 is offline
rokr1292 is on a distinguished road
No.
You'd have to make an absolute mess of the original enclosure, you'd be better off starting from scratch with MDF
rokr1292 is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 08:00 PM #28
I finally had the chance install the amp and the sub. It was a long process but if you're patient it comes out well. The only problem I had was that the amp I used (Kicker 46CXA400.1T amp) was great for size but was too deep. That in turn made the top clip not connect too well. I also had to shave one tab on the cover panel. Still a great little amp and the gap is minimal.
Old 06-26-2020, 03:52 PM #29
almost4rn almost4rn is offline
almost4rn is on a distinguished road
Hey man how did that Kicker CompRT 43CWRT81 sub fit in the stock enclosure?
Looking to get that but crutchfeild said it was too high and might hit the stock panel
almost4rn is offline   Reply With QuoteReply With Quote
Old 06-26-2020, 05:39 PM #30
chompster4runner chompster4runner is offline
chompster4runner will become famous soon enough
I just installed kicker comp 8in shallow in the stock sub box yesterday. You just have to align the sub as centered as you can when you screw down the sub. I looked thru the grill and the speaker rib are cleared. There is a slight gap between the panel and sub. I`d say 1/16th
OEM sub enclosure 861500W040-img_0129-jpg
2022 Toyota 4Runner TRD OFF ROAD PREMIUM
chompster4runner is offline   Reply With QuoteReply With Quote
amp , enclosure , oem , original , replace
WTB JBL sub enclosure 4th gen Antoddio Want to Buy/Trade 0 10-27-2015 08:42 AM
WTB 4th Gen JBL enclosure fullboogie Want to Buy/Trade 0 10-07-2015 06:12 PM
WTB: 4th gen JBL Sub Enclosure Box boom85 Want to Buy/Trade 0 11-08-2014 10:39 AM
WTB: OEM JBL Enclosure LTX4RUNNER Want to Buy/Trade 0 07-08-2010 03:31 AM
