Originally posted by nathannookie
Is there a place inside the dash, where you can get 12 volt power, even with the ignition switch turned completely off?
Also wondering where the best place is, to route wires through the firewall to aftermarket driving lights.
Thanks
You should be able to find lots of constant 12V power in the driver's side footwell. Just use the multimeter to find one, then tap into it. Just make sure the wire is sufficient to carry the load you need (you don't mention what you plan to run off of it).
On the Camry, finding a constant 12V supply was easier than finding a switched one.
Haven't looked at the firewall to see what might be there to route wiring for the lights.
