i think those are the bilstien 4600, you can see there is no adjustable lift.
like others have said, you can get 4600 for 100 less than 5100(360), only difference is that 4600 is not going to lift, 5100 can lift. some stay with .85 setting, some go all out.
on 5th gen , i see that the driver side is 1 clip setting higher than the passenger side. most of us just use same clip setting for both sides.
if you want to source out new springs, you should.
there is another guy here that sells dobinsons, pretty good stuff from what i see. contact them for a quote.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
