Old 03-02-2020, 12:21 AM #1
Swelden1 Swelden1 is offline
Swelden1 is on a distinguished road
Question 2008 4Runner, VSC light flashing, traction control and check engine light solid
Looking for some advice, I know this has been discussed before and I'll take some heat for not finding it on my own, but I haven't seen anyone post about an 08 specifically so here goes. Got in the runner the other day and the check engine light is lit solid, so is the traction control light, you know the one with the little car and skid marks behind it, the VSC light is flashing. All three, just having a grand ole time right there in the dash. I have an OEM gas cap that was put on a couple of years ago, I guess that could still be the problem, what I'm really looking for is the correct sequence including pin locations for a Zero Point Calibration, as I understand this could also be the issue. I apologize for the lengthy post but I've tried every iteration I can find, here and elsewhere and so far, no joy. Any thoughts?? TIA!!
Swelden1 is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 01:39 AM #2
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Probably the gas cap or the gas cap gasket.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 12:41 PM #3
November Sun November Sun is offline
November Sun is on a distinguished road
Gas cap. Mine does this when it's really cold outside. I've changed the cap, gasket and it still does it. I usually just re set it with my Scangauge and I'm good to go.
November Sun is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 12:51 PM #4
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
Don't guess, check the CEL diag codes. If you don't have a code reader, you should probably get one - they're like $20-$30 bucks on Amazon. Or, go to Autozone/Oreillys and have them read the codes for free. They'll even tell you what the codes mean and at least suggest some likely causes. It may have nothing to do with your gas cap.
Since the CEL is on, it's likely not the zero point calibration (a bad ZPC won't light the CEL). When the system detects a diag code, it lights the CEL. It also disables the VSC/TRAC system because the engine is in limp mode and the VSC software doesn't know how to compensate for the reduced engine performance. So, your CEL is pointing to the cause, while the VSC and TRAC lights are just side effects.
Short answer - figure out the cause of the CEL first.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 10:46 PM #5
Thanks for the information. I'll dig into it and update.
Old 09-01-2022, 12:39 PM #6
Christmas Christmas is offline
Christmas is on a distinguished road
Where's our update?
Christmas is offline   Reply With QuoteReply With Quote
Old 09-01-2022, 09:08 PM #7
meltdowner meltdowner is offline
Real Name: Tim
meltdowner is on a distinguished road
Real Name: Tim
Originally Posted by christmas View Post
where's our update?
i got your update for ya!!!
meltdowner is offline   Reply With QuoteReply With Quote
flashing , light , post , traction , vsc
Check engine, traction control, and VSC light on. BCKGUY 4th Gen T4Rs 5 01-31-2023 07:33 PM
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
Check engine along with traction control light came on, no idea why Nmac65 4th Gen T4Rs 11 03-11-2019 11:10 AM
VSC Off, Check Engine light and the traction control squiggly thing again... Nuke 4th Gen T4Rs 22 05-30-2016 09:39 PM
vsc, vsc off, traction control light, check engine lights Dunk50 General Discussions 1 10-26-2011 06:22 PM
