Old 03-14-2020, 06:42 PM #16
TheHennDoggg's Avatar
TheHennDoggg TheHennDoggg is offline
Real Name: Henry
TheHennDoggg will become famous soon enough
Real Name: Henry
Got some Centric brake lines for the ones that were cut by the people who got it before me at the junkyard
V8 4WD 8.2 Swap-img_0867-jpg
Ask me about my frame rust!
Major Parts List:
Energy Suspension, full front end rebuild, 885& Toytec, SPC upper arms, dual-amped 7 speaker stereo, 5100's, rear swaybar delete courtesy of rust, v6 junkyard skidplates and a lot of elbow grease
TheHennDoggg is offline   Reply With QuoteReply With Quote
Old 03-14-2020, 08:15 PM #17
Jembrmstr's Avatar
Jembrmstr Jembrmstr is offline
Real Name: Jacob
Jembrmstr is on a distinguished road
Jembrmstr's Avatar
Real Name: Jacob
I’m about 75% done with making an elocker work on my runner, I have a few sites that have really good instructions on how to do so, if you’re Interested send me a PM and I can text you links to the sites or someone can teach me how to hyperlink on the pages here from my phone.
2004 SR5 4WD 4.7l, FJ springs w/ 5100's front at 1.75" rear 1.5" poly spacer, led light strip on frame rails w/ dome light mod,FJ wheels, GY duratrac 285's, Smoke LED taillights, Rear bumper light MOD, all new Light housings up front, tint, ventshades, touchscreen Pioneer w/ backup cam
Jembrmstr is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 09:43 AM #18
Real Name: Henry
Real Name: Henry
It may not be a surprise to some of you, but here is confirmation that 8 inch and 8.2 inch axles can receive the same parts:
Went to the junkyard yesterday and picked up some hard brake lines, calipers and caliper brackets from a 2003 v6 4runner. These fit on the 2012 FJ axle perfectly, I even used the bolts and brackets from the junkyard on the new axle. Even less of a surprise is that the Metaltech LT brake lines (for my 2003 4runner) also fit. I have 1990 (or second gen) 4runner rear sway bar end links coming in soon and that will be about everything to have the axle in 100%.
I have not began making the locker harness yet as my attention for this first part is to have a drivable vehicle, especially since we cant wheel till mid May at the earliest due to the coronavirus in North Carolina . Will be getting the parts soonish, once I know the axle is in and working.
V8 4WD 8.2 Swap-img_0993-jpg  V8 4WD 8.2 Swap-img_0992-jpg  V8 4WD 8.2 Swap-img_0991-jpg  V8 4WD 8.2 Swap-img_0988-jpg  V8 4WD 8.2 Swap-img_0987-jpg
Major Parts List:
Old 03-27-2020, 09:46 AM #19
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Just copy and paste the links in a reply and they should auto-format for you.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 12:24 PM #20
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
Its super easy to make the elocker work manually. All you need to do is connect a momentary on-off-on switch to the motor using 2 relays in reversing polarity (like a window motor). The engage/disengage harness to the right of the motor connects to the light on the switch to tell you when it is fully engaged. Thats it.
There are other ways to do it that include using 4 relays, but those methods are both overcomplicated and provide less current to the motor making it take longer to engage.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 04:55 PM #21
Real Name: Henry
Real Name: Henry
Under the knife she goes. See y'all soon with the results
V8 4WD 8.2 Swap-img_1002-jpg
Major Parts List:
Old 03-28-2020, 09:06 PM #22
Real Name: Henry
Real Name: Henry
IT IS IN! It was a direct swap with no hiccups, thankfully. The worst part of the swap for me was the brake line brackets near the gas tank, but I was patient and managed to get them off without breaking anything. Literally couldnt have done it without my boi @That_Titanium_4RNR
Parts list:
2012 FJ 8.2 w/elocker
Axle Soft Brake Lines
CENTRIC 15044407
CENTRIC 15044408
Rotors and Pads
DURAGO BK9139116
DURAGO BR90091202
DURAGO BP606C
Sway Bar End Links
MEVOTECH GS86809
Metal Tech LT Stainless Steel brake lines
Hard brake lines and calipers from a 2003 4runner v6
Like 3 quarts of spilled brake fluid
I did a full E-brake delete because mine hasn't worked for 4 years and I didn't wanna mess with it just yet
V8 4WD 8.2 Swap-img_1029-jpg  V8 4WD 8.2 Swap-img_1027-jpg  V8 4WD 8.2 Swap-img_1022-jpg  V8 4WD 8.2 Swap-img_1018-jpg  V8 4WD 8.2 Swap-img_1016-jpg
Major Parts List:
Old 03-28-2020, 09:14 PM #23
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Parts list:
CENTRIC15044407
CENTRIC15044408
Rotors and Pads
DURAGOBK9139116
DURAGOBR90091202
DURAGOBP606C
Sway Bar End Links
MEVOTECHGS86809
Also to those who may be concerned, the ebrake stuff would have worked too but we just decided to leave that for another time. The cables seem to be the same between 4th and 5th gens. At least at the ends
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 02:31 PM #24
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Damn, I need to go hunting for one of these! I have no idea how you got it for such a steal! Good job!
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 04:39 PM #25
awhitney1 awhitney1 is offline
awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about
THATS IT! this whole 8.2 inch swap got me cookin in my pants and decided to go with the $6700 route with Just differentials. FRESH PARTS!
Toyota 8.2" axle kit
awhitney1 is offline   Reply With QuoteReply With Quote
beginning , fit , modifications , needed , swap
Bad_Vision's 1985 Toyota 4RUNNER TDI Swap (Completed swap) Bad_Vision Classic T4Rs 211 10-06-2019 10:56 PM
my 92 budget build. engine swap and front end swap? bhenry92 Classic T4Rs 4 08-06-2013 05:42 PM
Im starting to get the 2.5yr blues...solid front axle swap or lt1 ls1 v8 swap? 240m3srt 3rd gen T4Rs 29 10-03-2011 12:15 AM
94 4runners-engine swap, or front end swap? pats for sale as well jimmy94 Classic T4Rs 7 05-16-2011 09:48 PM
92 fourrunner swap 3.0 L standard Engine Swap compatibility cshlakoff Classic T4Rs 0 02-17-2008 12:42 PM
