Old 03-03-2020, 02:26 AM #1
Tuby27 Tuby27 is offline
Tuby27 is on a distinguished road
retrofit wiring question
hi all, I'm retrofitting my headlights on my 04 4runner. I went with Morimoto's bi-xenon mini h1 with stock high beams. I did not know I needed to and did not purchase the y-splitter and not sure how it works as the photos does not indicate how they are wired. my understanding is the two wires that turns on the bixenon high beams (white and brown) should be wired to the factory high beams, am I correct? the y-splitter does not show any connecting wire harness for the bi-xenon projector wires. would I just wire the two thin bi-xenon projector wires ( white and brown) to the factory high beams? pics would be appreciated, thanks.
Daily: 2004 4Runner SR5 V6 4x4
Pleasure: 2007 Tacoma DCLB TRD Sport 4x4
Tuby27 is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 05:42 AM #2
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
The “molex” bi-xenon connector plugs into the solenoid on the projector and the other side should be 9005 which connects to the stock harness. The splitter splits this in 2 - one side 9005 that connects to the harness and the 2 other sides go to either the solenoid or the stock high beam.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 09:12 AM #3
bkim7 bkim7 is offline
Real Name: Brian
bkim7 is on a distinguished road
Real Name: Brian
DM is correct. I have an 03 with Morimoto Mini H1s with a high beam splitter so I can try and get you some pictures later. Another way to put it, if you orient the high beam splitter like the letter "Y", the bottom of the "Y" goes to your stock high beam harness and then one branch of the "Y" goes to the projector solenoid and the other branch of the "Y" goes to your high beam bulb.
2011 Lexus ES 350 Smoky Granite Mica
SOLD: 2003 White (w/ cladding), SR5, 4WD, V8, 105K miles as of 03/2020
Morimoto MH1 7.0 HID Retrofit w/ 4500 K Bulbs, Kenwood Excelon Head Unit, Infinity Reference 6.5" Component Speakers, Amber Grille Lights
bkim7 is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 04:33 PM #4
Thanks. So better to do it clean and just get the y-splitter. Are they the same or is there a specific part number? Thanks
Old 03-03-2020, 05:11 PM #5
just a standard 9005 Y-splitter. Lightwerkz/TRS sells 'em, but after shipping, I'd probably just go the Amazon route.
Something like this will work just fine.
Old 03-03-2020, 05:43 PM #6
Real Name: Brian
Real Name: Brian
Yes I would just get the splitter as they aren't very expensive. What DM posted should work, looks very similar to what I ordered from Lightwerkz.
Old 03-07-2020, 02:33 PM #7
Will see how it goes. Thanks for the clarifications.
retrofit wiring question-ded80223-ba09-483d-87e7-f105d6b49b5d-jpg
Old 03-07-2020, 07:10 PM #8
Take pics if you get confused on what goes where and we can try to help if you need.
Old 03-23-2020, 08:36 PM #9
SilverBullet01's Avatar
SilverBullet01 SilverBullet01 is offline
Real Name: Taylor
SilverBullet01 is on a distinguished road
Real Name: Taylor
those turned out clean. post an output picture with the hightbeams on if you get the chance.
'05 Galactic Grey Mica sport 4.7 4WD
SilverBullet01 is offline   Reply With QuoteReply With Quote
Old 04-15-2020, 01:34 AM #10
I think the painted highs looks good during the day but not as bright as It being unpainted. Good thing my projectors are bixenon, with the wire harness I’m running quad highs. Probably search for a mod to make them daytime lights with my halos. Also did the stage 1 fog mod so I can turn them on anytime except when running the highs.
retrofit wiring question-f3d72f5c-404a-4e9b-a5f6-c02be48221e8-jpg  retrofit wiring question-e01efbc3-e89e-4656-80b3-2f4bdf9b7cc0-jpg
Old 04-15-2020, 11:17 AM #11
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
I can help you with that I'm assuming you still have OEM DRLs right?
Old 04-15-2020, 01:34 PM #12
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough
Yoooo twinsies. Minus halos haha.
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 04-15-2020, 01:35 PM #13
Just to stay on topic, get the hi beam splitter to make everything plug and play.
07 SR5 4x4
Old 04-16-2020, 11:37 AM #14
No my 2004 sr5 never had DRL unless your talking about the parking lights?
Old 04-16-2020, 11:38 AM #15
Yup got it and it is plug and play. Thanks
beams , bi-xenon , factory , high , wires
HID Retrofit - LED switchback wiring help Hoju 5th gen T4Rs 17 04-22-2020 12:21 AM
Headlight wiring: Adapting H4 to 2 2-pin for projector retrofit PotentSeaMen 3rd gen T4Rs 6 04-09-2019 10:30 AM
How To: DIY 3rd Gen 4Runner 8" Retrofit Elocker Wiring JWaldz 3rd gen T4Rs 31 03-04-2018 11:20 PM
HELP: Very Strange E-locker Wiring Retrofit Issue BrandonF 3rd gen T4Rs 5 09-01-2014 04:15 PM
Elocker retrofit wiring harness cj80cruiser 3rd gen T4Rs 4 06-22-2013 04:16 AM
