Old 08-04-2020, 06:26 PM #31
TheHennDoggg's Avatar
TheHennDoggg TheHennDoggg is offline
Real Name: Henry
TheHennDoggg will become famous soon enough
Real Name: Henry
Took some really clean shots with my sister’s DSLR and MAN I can’t wait for a bigger lift and 35s. Speaking of more lift... Dobinsons springs came in today, taco tabs come in Thursday!
Ask me about my frame rust!
Major Parts List:
Energy Suspension, full front end rebuild, 885& Toytec, SPC upper arms, dual-amped 7 speaker stereo, 5100's, rear swaybar delete courtesy of rust, v6 junkyard skidplates and a lot of elbow grease
TheHennDoggg is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 07:19 PM #32
montijo505's Avatar
montijo505's Avatar
I would also do the All Pro cam tab gussets while you're in there. They go hand in hand and the fitment is great. Easy install also.
Shots are clean! Nice job.
Sent from my SM-G986U using Tapatalk
Old 08-09-2020, 02:52 PM #33
Real Name: Henry
Real Name: Henry
I think I’m going to do the marlin crawler gussets down the line, they are super beefy. I just can’t weld in the garage where I live right now so I need to wait to do them
Major Parts List:
Old 08-09-2020, 02:55 PM #34
Real Name: Henry
Real Name: Henry
Went to uwharrie this weekend and had a blast. My buddies in the RAV4, Outback and Forester always turn heads on the trail. The locker has a surprisingly steep learning curve with how much agility you lose when you turn it on!
Major Parts List:
Old 08-14-2020, 07:35 PM #35
Real Name: Henry
Real Name: Henry
I added taco tabs, deleted my swaybar and added C59-354 Dobinson’s springs this week. I’m very happy I did this mod! Here are the results:
Went from ~3 inches of front rake to ~1 inch, making it look much more level and very capable of handling the big boi weight that lies ahead
Deleting the swaybar and replacing it with 730lb/in springs feels really good. It took away some undesirable handling characteristics (like the steering wheel “sticking” in parking lots at full lock) and no noticeable downsides. I feel confident driving it around and I couldn’t ever say that before on the 885’s with no sway bar.
Cranked my caster from 3 degrees to about 5 and made the front end a lot stronger with the taco tabs
These springs are stiff but not “bad” stiff. The ride is comparable to the 885’s plus swaybar.
Some pics:
Major Parts List:
Old 09-16-2020, 10:26 AM #36
Real Name: Henry
Real Name: Henry
Made some AdventureIndex drawers and got to test them out this last weekend! I made them out of MDF, the total cost came to around $350. My dad and I took two weeks and made them after work. I need to make a latching system so that it stays closed, but I’m happy with where they are and will be keeping them in the runner “full time”. Even with a 12 inch sub, there are no rattles and only make noise when they open a little on harder acceleration.
Here are some progress pictures:
A LOT of money on slides:
Carcass mostly complete:
Interior drawer complete:
Mating the two together:
Utensils drawer and front complete:
Carpeting done, decided to make a second one after I liked the first so much:
Storage view:
Major Parts List:
Old 09-16-2020, 03:21 PM #37
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Those look really good! I like the carpeting vs some others I've seen as bare wood or just paint. How did you attach the carpeting? I see some staples on top of the face, but did you need and contact cement or maybe some special carpet adhesive to make it stick well on the large areas?
Also really random, but I see you have a picture of a RD688 Mack (maybe 690?), which I like. I drove one off highway for a summer job and I just really like that body style.
y=mx+b is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 09:22 AM #38
Real Name: Henry
Real Name: Henry
Thanks man! I’m a complete beginner to this, so I just used adhesive for the large faces and staples the hell out of the corners so they wont come up. They don’t look the prettiest but it should last long!
And yes, it’s an RD I’m not sure the model. My dad has worked as an engineer for Mack trucks for a LONG time and graduated from Penn state, so that picture was perfect to hang up. I was gonna work as an engineer at Mack too until covid happened, but I just accepted a job with the department of defense to help design naval warplanes and I couldn’t be more excited TheRustyRunner Build Thread
Major Parts List:
Old 09-17-2020, 10:41 AM #39
y=mx+b's Avatar
y=mx+b's Avatar
Cool, I really like how yours turned out, the carpeting looks good.
Bummer that COVID screwed up your plans, but seems you found another great opportunity! That sounds like more 4runner budget to me lol
build , front , rear , replacement , spc
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
