Old 03-05-2020, 01:16 AM #1
prule84 prule84 is offline
prule84 is on a distinguished road
Fog Light Issue
Hey guys,
I've done a ton of searching, but can't come up with a solution or a similar scenario.
I installed an ARB bumper ~1.5 years ago, and decided against installing fogs at the time. I decided I needed a new mod, so I bought these on Amazon and they just arrived today. They plug directly into the OEM fog harness, but even with the truck on and both the headlights and fog light switches on, I get nothing from the new fogs. I tried plugging the fogs into the low light harness, and they work no problem. Is it possible that the fog harness is damaged/ruined since it hasn't been in use at all for the past 1.5 years?
Any ideas? I swapped the fog & AC relays to see if that was the issue, but same result.
Thank you!
2005 unLimited V6 Stratosphere Mica
prule84 is offline   Reply With QuoteReply With Quote
Old 03-05-2020, 01:30 AM #2
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Originally Posted by prule84 View Post
Hey guys,
Thank you!
Check the polarity, it might be reversed.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 03-05-2020, 01:41 AM #3
Okay, I will do that. If that were the issue, what would the proper resolution be?
[edit]
And actually, the fogs wouldn't work in the low light harness if the polarity was reversed right? So I wonder if it's something else.
Old 03-05-2020, 02:00 AM #4
[edit]
Not sure what the wiring looks like but mine used a Deutsch DT adapter that I was able to open up and flip wires in the connector itself - if not, cutting the wires and re-wiring/soldering would also work.
It may or may not work there...depends on the polarity if the low beam harness wiring vs the fogs. You could also maybe check the fuse for the fogs?
Old 03-05-2020, 02:09 AM #5
I didn't have a spare fog bulb to test, but I did use a lowlight bulb in the fog connector and that also didn't get any power. I'll check the fuse tomorrow.
Old 03-05-2020, 02:14 AM #6
Makes me think there is no power coming through at all. A multimeter would confirm this, but I think you can squeeze a high beam bulb (9005 high beam vs 9006 fog) in there and see as well. Hopefully it’s just the fuse.
Old 03-06-2020, 12:53 AM #7
Looks like it was indeed a blown fuse. Haven't had a chance to test the fogs with a new fuse yet, but my multimeter confirmed the fog fuse was blown.
Old 03-06-2020, 01:28 AM #8
Awesome! It's always the simplest things lol.
Old 03-06-2020, 10:10 PM #9
Oh I’m sure something else unforeseen will happen before this mod is complete
Btw I was looking into retrofitting my headlights and have been reading through your threads. Any tips you can offer? I’ll be using my 05 OEM housings, so a little bit different. Why did you choose the G5-BRT over the G5-R or even the Morimoto? Why the Hylux 45W over the Morimoto?
Old 03-06-2020, 11:48 PM #10
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Hylux costs less and has a very low failure rate compared to Morimoto...TRS even decided to have Hylux manufacture their latest ballasts.
Old 03-07-2020, 12:08 AM #11
05 pre-refresh you should go with the something threaded. I went BRT over R for the AR coating and a tiny bit extra output. I liked the G5 variants’ beam pattern over the Morimoto offerings. Hylux for the same reason Ed said, much lower failure rate.
Old 03-07-2020, 01:11 AM #12
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Yup, easier to do a shaft-mount retro on pre-facelift 4th-gens.
H1-type projectors won't require opening up the bulb hole but I'd just use a hole saw or unibit (apparently the largest Harbor Freight one is almost perfect in size) to open it up and do a D2S type projector like G5-R or D2S 5.0, or even a MLED 2.0 (bi-LED)
Old 03-07-2020, 04:17 PM #13
This guy knows all about hole saws! LOL
Old 03-11-2020, 01:25 PM #14
Stupid question - what do you mean by something threaded? Would the Morimoto Mini D2S Stage III fit that criteria?
Old 03-11-2020, 07:52 PM #15
A projector with a threaded mounting means you can secure the projector through the through the pre-existing hole in the back of the reflector.
The Morimoto Mini D2S 5.0 kit or G5-R kit would both work for reflector housings.
decided , fog , fogs , harness , light
ABS light vs. batt. light issue Hippo393 3rd gen T4Rs 9 06-04-2017 01:26 PM
Fog Light Issue sixlug 4th Gen T4Rs 3 09-19-2012 05:30 PM
Fog light issue please help! zstampe 4th Gen T4Rs 4 10-25-2010 07:29 PM
o/d off light issue tylr_byrd Classic T4Rs 4 02-05-2009 12:28 PM
Map light issue, can anyone w/ a FSM help? brown_eyes 3rd gen T4Rs 4 11-25-2006 06:21 PM
