03-05-2020, 01:16 AM
#1
Member
Member
Fog Light Issue
Hey guys,
I've done a ton of searching, but can't come up with a solution or a similar scenario.
I installed an ARB bumper ~1.5 years ago, and decided against installing fogs at the time. I decided I needed a new mod, so I bought these on Amazon and they just arrived today. They plug directly into the OEM fog harness, but even with the truck on and both the headlights and fog light switches on, I get nothing from the new fogs. I tried plugging the fogs into the low light harness, and they work no problem. Is it possible that the fog harness is damaged/ruined since it hasn't been in use at all for the past 1.5 years?
Any ideas? I swapped the fog & AC relays to see if that was the issue, but same result.
Thank you!
__________________
2005 unLimited V6 Stratosphere Mica
03-05-2020, 01:30 AM
#2
Member
Member
Quote:
Originally Posted by prule84
Hey guys,
Thank you!
Check the polarity, it might be reversed.
__________________
2006 4Runner Sport Edition V8 4WD
03-05-2020, 01:41 AM
#3
Member
Member
Quote:
Okay, I will do that. If that were the issue, what would the proper resolution be?
[edit]
And actually, the fogs wouldn't work in the low light harness if the polarity was reversed right? So I wonder if it's something else.
__________________
03-05-2020, 02:00 AM
#4
Member
Member
[edit]
Not sure what the wiring looks like but mine used a Deutsch DT adapter that I was able to open up and flip wires in the connector itself - if not, cutting the wires and re-wiring/soldering would also work.
It may or may not work there...depends on the polarity if the low beam harness wiring vs the fogs. You could also maybe check the fuse for the fogs?
__________________
03-05-2020, 02:09 AM
#5
Member
Member
I didn't have a spare fog bulb to test, but I did use a lowlight bulb in the fog connector and that also didn't get any power. I'll check the fuse tomorrow.
__________________
03-05-2020, 02:14 AM
#6
Member
Member
Makes me think there is no power coming through at all. A multimeter would confirm this, but I think you can squeeze a high beam bulb (9005 high beam vs 9006 fog) in there and see as well. Hopefully it’s just the fuse.
__________________
03-06-2020, 12:53 AM
#7
Member
Member
Looks like it was indeed a blown fuse. Haven't had a chance to test the fogs with a new fuse yet, but my multimeter confirmed the fog fuse was blown.
__________________
03-06-2020, 01:28 AM
#8
Member
Member
Awesome! It's always the simplest things lol.
__________________
03-06-2020, 10:10 PM
#9
Member
Member
Oh I’m sure something else unforeseen will happen before this mod is complete
Btw I was looking into retrofitting my headlights and have been reading through your threads. Any tips you can offer? I’ll be using my 05 OEM housings, so a little bit different. Why did you choose the G5-BRT over the G5-R or even the Morimoto? Why the Hylux 45W over the Morimoto?
__________________
03-06-2020, 11:48 PM
#10
Senior Member
Real Name: Ed
Senior Member
Real Name: Ed
Hylux costs less and has a very low failure rate compared to Morimoto...TRS even decided to have Hylux manufacture their latest ballasts.
03-07-2020, 12:08 AM
#11
Member
Member
05 pre-refresh you should go with the something threaded. I went BRT over R for the AR coating and a tiny bit extra output. I liked the G5 variants’ beam pattern over the Morimoto offerings. Hylux for the same reason Ed said, much lower failure rate.
__________________
03-07-2020, 01:11 AM
#12
Senior Member
Real Name: Ed
Senior Member
Real Name: Ed
Yup, easier to do a shaft-mount retro on pre-facelift 4th-gens.
H1-type projectors won't require opening up the bulb hole but I'd just use a hole saw or unibit (apparently the largest Harbor Freight one is almost perfect in size) to open it up and do a D2S type projector like G5-R or D2S 5.0, or even a MLED 2.0 (bi-LED)
03-07-2020, 04:17 PM
#13
Member
Member
This guy knows all about hole saws! LOL
__________________
03-11-2020, 01:25 PM
#14
Member
Member
Stupid question - what do you mean by something threaded? Would the Morimoto Mini D2S Stage III fit that criteria?
__________________
03-11-2020, 07:52 PM
#15
Member
Member
A projector with a threaded mounting means you can secure the projector through the through the pre-existing hole in the back of the reflector.
The Morimoto Mini D2S 5.0 kit or G5-R kit would both work for reflector housings.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
