Old 08-18-2020, 10:31 AM #1
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Sway bar bushing prioritizing off road?
Looks like I need to replace my sway bar bushings. I know the Prothane and Energy options are both supposed to improve on-road performance. My question is has anybody found a bushing option that is looser for off-road? I'm probably about to get Mstudt end links as well as soon as my next pay check hits.
Trying to tighten up a couple of annoyances that have been stuck on the "fixin to do" list for a while.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 11:51 AM #2
gaswede gaswede is offline
gaswede is on a distinguished road
I just ordered all new rod ends and bushing myself. I went with rubber bushings for that exact reason. plenty of cushion for on-road and a little more give for off-road. I use the poly stuff for on-road vehicles only. sure, you'll need to replace the rubber ones more often but we're talking years in between replacements.
gaswede is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 12:41 PM #3
Which rubber ones did you use? Did you find ones with a grease zerk?
Trying to decide whether the answer is rubber, or poly with discos so its irrelevant off road xD
Old 08-18-2020, 01:06 PM #4
Just went back and looked at my order. Looks like I was on a late night Moog kick. I ended up getting front moog poly bushings and Dorman rubber for the rear. Oh well. All my links are Moog with the rears being the 2nd gen design. I didn’t get the greasable kits.
Having the discos will be nice. Would love to see them when you get them installed.
Old 08-18-2020, 04:18 PM #5
montijo505's Avatar
montijo505's Avatar
I've run energy red poly greasable rear sway bar bushings for quite a few years with no issues.
Also ran them on the front until I ditched the front sway bar.
Sent from my SM-G986U using Tapatalk
Old 08-19-2020, 11:51 PM #6
morphious's Avatar
morphious morphious is offline
Real Name: John
morphious is on a distinguished road
morphious's Avatar
Real Name: John
Just remove your sway bars!
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
morphious is offline   Reply With QuoteReply With Quote
bar , bushing , mstudt , pay , sway
Can you post a pic of your sway bar bushing? SendInTheCavalry 5th gen T4Rs 1 06-02-2019 09:51 AM
I need some front sway bar bushing help... ShooterMcGavin 3rd gen T4Rs 8 10-10-2016 02:05 PM
Need from sway bar bushing mounts!!! Help? az98trd 4th Gen T4Rs 12 11-04-2013 10:45 PM
Sway Bar Bushing Maritimer 3rd gen T4Rs 15 07-10-2011 04:45 PM
sway bar bushing riceandpho 4th Gen T4Rs 1 01-16-2009 09:26 AM
