Old 03-04-2020, 01:28 AM #1
cjm2022 cjm2022 is offline
cjm2022 is on a distinguished road
Frame rust... how long do I have?
I found some rust on my 2003 V8. I was planning on lifting it and getting sliders soon. Now I'm not sure what I should do. The pictures are after some time with a wire wheel. I put POR 15 on it afterward. What are my options? Can it be cut out and patched?
Thanks in advance.
Frame rust... how long do I have?-20200301_144330_copy_1612x1209-jpg  Frame rust... how long do I have?-20200301_144333_copy_1612x1209-jpg  Frame rust... how long do I have?-20200301_144321_copy_1612x1209-jpg
cjm2022 is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 09:47 AM #2
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
aside from that one spot it looks pretty nice
hinmo24t is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 09:56 AM #3
Monty87ls Monty87ls is offline
Monty87ls is on a distinguished road
Maybe find a local welding shop and see what they can do for you? I'm gonna do that for my rad support once its on the road.
Monty87ls is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 10:04 AM #4
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Is that dirt behind there? Does the rust go all the way through the frame? Definitely clean it out. That's probably why the rust is there.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 11:35 AM #5
that has definitely gone through the frame from inside & out. could probably poke a hole in it with a screwdriver. never seen it that bad on a 4th gen. mine is from the midwest & had some surface rust where the black coating failed & some surface rust on the welds, but nothing like that.
por wont do anything for that if its just applied to teh outside & even if it was applied inside too it wouldnt help being that far gone. i would cut that out & patch it asap if you want to save it from getting worse.
Old 03-04-2020, 01:47 PM #6
Thanks for the responses guys. It was actually surprisingly rigid I dont think I could poke a hole in it with a screwdriver.
Either way I'm calling a local shop to see what they can do.
I realize this could vary geographically, about how much do you think it might cost to cut out and replace?
Old 03-04-2020, 02:17 PM #7
Inv4drZm's Avatar
Inv4drZm's Avatar
It seriously looks like the frame is rusted all the way through and there is dirt behind there, please investigate that and poke it harder.
As for welding it will be easy just a single flat plate should do the trick. Couple hundred bucks at max.
Old 03-04-2020, 02:24 PM #8
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Right by the cat. Very common rotting point on 4th gens and Tacos.
Old 03-04-2020, 05:23 PM #9
MikeinNH67's Avatar
MikeinNH67's Avatar
Rap that with a pointy hammer and it will go through. That's no longer steel in my opinion. Call around and see if someone will weld a plate in. You may be able to save some by doing the prep-work yourself.
If mine, I would cut back until I found solid steel then make a plate that fit inside the new hole. Then I'd weld it up with my mig.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 03-04-2020, 05:23 PM #10
When you say dirt behind there. Are you saying that there is dirt behind the rust flakes? or on the inside of the frame?
Old 03-04-2020, 05:28 PM #11
Inv4drZm's Avatar
Inv4drZm's Avatar
I'm saying the 1st picture with all the cracks. That looks like dirt. Not metal or rust flakes.
You can see where the frame rail, only about 1/8" thick, is pulled away and that dirt crap is all that's left just behind where it would be.
Unless the picture is playing tricks on me.
Old 03-04-2020, 06:27 PM #12
I hit the area with all the cracks pretty hard with a wire wheel. It's metal... well it used to be now it's just rust. I called a local welding shop today I'm going to take it in there ASAP. Unfortunately it won't be for about 2 weeks. I'll definitely post an update and let y'all know what's going on.
Old 03-04-2020, 06:55 PM #13
Its gonna get taken care of which is most important. Mine should be on the road next week and I'm gonna get it looked at.
Sent from my SM-N975U1 using Tapatalk
Old 03-05-2020, 04:32 PM #14
MikeinNH67's Avatar
MikeinNH67's Avatar
Ouch. I'd like to hear your plan for that repair.
Mike
03 4runner Limited
Old 03-05-2020, 04:49 PM #15
I would too!
Sorry to say this but it makes me feel better about mine. It was the first vehicle I purchased when I got my first full time job and I'd like to keep it for as long as possible.
por , put , rust , wheel , wire
Frame rust someone tell me ho bad it is Arnezie 3rd gen T4Rs 26 04-15-2019 01:11 AM
Need Advice: Frame Damage From Accident and Frame Rust Whammy 4th Gen T4Rs 11 08-29-2018 07:46 PM
98 Frame rust KimbeR22 3rd gen T4Rs 8 07-14-2015 06:54 PM
To all with frame rot and rust through T4Rscott 3rd gen T4Rs 46 05-25-2014 04:52 PM
How much frame rust is too much? GypsyRose 3rd gen T4Rs 11 10-21-2012 07:07 AM
