Old 03-09-2020, 03:11 PM #1
sonicc sonicc is offline
sonicc is on a distinguished road
Banging/clunking noise after brake replacement
Replaced pads and rotors on the 4R over the weekend. Went for a drive and there's a loud banging from the rear. Oddly enough, the noise disappears once you hit 20-25mph and it doesn't come back until the car is parked. It doesn't make the noise at any point during braking or normally driving. I've noticed the only time it will start is if it was parked with parking brake engaged. If I park without engaging parking brake and then go for a drive, it doesn't do it.
Went and rechacked to make sure caliper bolts and caliper carrier bolts are tight. Made sure all the new brake hardware is still in place. couldn't see anything obvious.
Here's the video:
https://www.youtube.com/watch?v=75Otla34RkQ&feature=youtu.be
sonicc is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 03:20 PM #2
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Here's the video:
The ebrake system on these trucks are very problematic. There are two pins that hold on the ebrake shoes. They're secured with springs. Overtime the pins straighten out and come into contact with the back of the axle flange area. You're in for a fun time!! ask me how I know...
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 03:22 PM #3
Sounds like a good time. So maybe just best to order new brake shoes and hardware?
Old 03-09-2020, 03:23 PM #4
Real Name: Michael
Real Name: Michael
generally it can be fixed with new hardware alone. The shoes dont need to be replaced unless theyre low on material or something is overtly wrong with them. Its really just those pins
Old 03-09-2020, 03:33 PM #5
When I looked at them, they were down to about 50%, so if I go replacing hardware might as well do the shoes.
Just weird that it started making the noise after i replaced pads and rotors. Must have pulled on the shoe a little when I was removing the rotor which put stress on the pin(s).
Old 03-09-2020, 03:34 PM #6
Real Name: Michael
Real Name: Michael
When you take off the rear rotor it generally causes this issue. Pins get pulled and straightened out
Old 03-09-2020, 03:53 PM #7
LOL...lucky me. thanks for the info
Old 03-09-2020, 04:08 PM #8
Real Name: Michael
Real Name: Michael
No problem, have fun!
Old 03-09-2020, 06:26 PM #9
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Generally if you just pull the rear rotors off without backing off the adjuster for the parking brake shoe you will almost always damage the mounting hardware for the shoes.
2004 Limited V8
Old 03-09-2020, 07:21 PM #10
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
Just an FYI, do not get an aftermarket hold down kit. I have been fighting a noise for years in the back. I shimmed the pins with a cut washer and it worked for the moment. I bought a OEM set and the pins were 1/8 shorter and they work perfectly.
The aftermarket set i bought was Carlson.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 08:46 AM #11
I'll have to keep that in mind. This is my first truck-ish vehicle, all others just had the regular disc brake in the rear.
Old 03-15-2020, 06:28 PM #12
Just wanted to update this thread in case someone comes across it in future...
Replaced parking brake shoes with all new hardware and noise went away.
Will need to adjust the parking brake some more as it's not holding at all now. But at least noise is gone.
bolts , brake , caliper , noise , parked
Loud banging noise post lift. Miyota 3rd gen T4Rs 3 03-13-2016 02:53 PM
After lift banging noise grannyzpanniez 3rd gen T4Rs 17 05-12-2015 11:20 PM
weird banging noise rayl82 Classic T4Rs 3 09-16-2013 02:33 PM
Clunking noise when I brake and codes on/off RunnerJeff 4th Gen T4Rs 9 06-25-2013 02:49 PM
Banging after axle replacement Nelsonmd 3rd gen T4Rs 19 02-16-2011 05:01 PM
