03-10-2020, 02:19 AM
No rear window wiper, washer, defog- NOT FUSE
As title says, my rear window wiper, washer, and defog don't work, but it does not seem to be a blown fuse (unless it's labeled something really weird).
2006 Sport Edition, V6, RWD
Any thoughts?
Thanks!
03-10-2020, 03:07 AM
Any thoughts?
Thanks!
This may sound goofy but did you make sure it's all the way rolled up? This happened to me once and it was rolled down just slightly so you couldn't even notice.
03-10-2020, 08:56 AM
Real Name: Todi
Real Name: Todi
+1 on this. It drove me nutz to two weeks until I figure it out...
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
03-10-2020, 10:55 AM
Run window all the way down, then all the way up. May want to do this with drivers door window and moonroof also.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
03-10-2020, 10:59 AM
Happened to me too.
03-12-2020, 01:23 AM
Real Name: Jacob
Real Name: Jacob
same here, also try to roll it up from the back and “help” it a little when it gets to the top. Check your wiper position too, my first gen was super finicky about the wiper position, had to manually move the wiper up and down to find the right spot with the key in the lift gate. Huge PITA
good luck, let us know what you found
2004 SR5 4WD 4.7l, FJ springs w/ 5100's front at 1.75" rear 1.5" poly spacer, led light strip on frame rails w/ dome light mod,FJ wheels, GY duratrac 285's, Smoke LED taillights, Rear bumper light MOD, all new Light housings up front, tint, ventshades, touchscreen Pioneer w/ backup cam
03-12-2020, 09:51 AM
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
03-13-2020, 12:10 AM
That was it!
Thanks!
