Real Name: Ron
Real Name: Ron
You changed the battery and cleaned up the connections, so it's a bit hard to tell which was the real culprit. However, the stalling was likely due to intermittent connections, but a bad battery with an intermittent shorted cell can also cause issues like that.
As said, your current observations indicate everything is now working properly.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
