Old 03-10-2020, 10:38 AM #1
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Battery resting voltage 12.8V when truck is off. Is that ok?
This past sunday I drove around 40 miles and did an all day hike. Got back to the car 8 hours later and it started right up. I drove 5 miles to a restaurant and when I got back in the truck 40 min later it would not start. The battery was completely dead.
I got it jumped and the 40 mile trip home the truck would stall for half a second and come back on. It did this 4 times on the way home.
I pulled the old battery and put in a brand new battery. I then wire wheeled every pos and ground going to the battery at the terminals and the ground to fender to make sure all connections are good.
I drove into work this morning and I watched my Scangauge II. the voltage put out while driving is 14.0-14.1V.
When I turned off the truck and went into the building it read 12.8V.
Is a resting 12.8V correct? Or do I need to start checking other connections and the alternator?
(483,333 miles, 2008 Sport Edition 4.7L V8)
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 10:50 AM #2
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Yes this is what it should be, the system is 12 volts. Less is discharging more is charging. You want to see between 13.5 to 14.5 with the truck running (alternator is doing it's job). Off anything right around 12 volts is good, what volts can't tell you are the available amps, but in your situation everything is presumably fine unless it's still stalling... is it?
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 10:51 AM #3
Burt Burt is offline
Burt is on a distinguished road
Looks good. Batteries do fail.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
Burt is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 10:56 AM #4
With the new battery in it is not stalling. I assume the battery was so drained that the alternator could barely keep up for the drive home.
Been reading other sites since I posted this and it looks like 12.8V resting is appropriate.
Old 03-10-2020, 11:31 AM #5
montijo505's Avatar
montijo505's Avatar
Nobody is gonna comment on the 480+k odometer? Holy cow!
Sent from my SM-G986U using Tapatalk
Old 03-10-2020, 12:13 PM #6
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
You changed the battery and cleaned up the connections, so it's a bit hard to tell which was the real culprit. However, the stalling was likely due to intermittent connections, but a bad battery with an intermittent shorted cell can also cause issues like that.
As said, your current observations indicate everything is now working properly.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 02:13 PM #7
gfxcruncher's Avatar
gfxcruncher gfxcruncher is offline
gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about
IKR?? @randy88fj62 That's damn impressive!
Mileage Goals!
2007 SR5 4WD Nautical Blue -- Build Thread
gfxcruncher is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 03:13 PM #8
Original engine / trans /etc. Still going strong. Dealer maintained until I bought it and now I do all the maintenance.
Old 03-10-2020, 04:40 PM #9
lightfreak lightfreak is offline
lightfreak will become famous soon enough lightfreak will become famous soon enough
You want to see 12.6v-12.8v idle with a new battery.
As it ages the resting voltage diminishes. My 10 year old Optima Red started showing 12.0v to 12.1v idle in the last couple months,even after a long drive, little too low for my liking, so I just changed it out last week for an Energizer AGM from Costco. Shows 12.8v idle, 13.5v-14.2v while running.
2004 4Runner Limited V6 4WD ***SOLD***
385,000 Km
Titanium Metallic
Vehicles: '21 Highlander XSE V6 AWD | '21 Acura RDX SH-AWD Tech | '03 Honda CBR600F4i
lightfreak is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 07:53 AM #10
miller507's Avatar
miller507 miller507 is offline
miller507 will become famous soon enough
miller507's Avatar
I just went through with an alternator rebuild, I have voltmeter wired in and it shows 13.8 on start up, 12.8-13.3 while driving and 12.5-12.8 at idle.
Multimeter shows 13.8 directly from battery
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
miller507 is offline   Reply With QuoteReply With Quote
Old 08-12-2020, 03:25 PM #11
gloch gloch is offline
gloch is on a distinguished road
Old post, but...480K! I sooo want my runner to go that long.
Well done!
gloch is offline   Reply With QuoteReply With Quote
Old 08-12-2020, 08:34 PM #12
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
It did take 12 years to do it, haha!
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
back , battery , drove , miles , truck
Voltage of Battery with Engine Running JP4RNR 4th Gen T4Rs 16 12-25-2022 01:17 AM
Battery/Alternator issue. Voltage is OK greif07 3rd gen T4Rs 98 10-05-2019 04:04 PM
Battery Voltage Help The Jc2203 3rd gen T4Rs 3 06-05-2015 07:09 PM
What is your measured Voltage at the battery with the truck on? kman79 4th Gen T4Rs 8 09-03-2013 11:32 PM
Battery Corrosion Vs Voltage Reglator Lobo 3rd gen T4Rs 6 01-02-2006 01:29 PM
