Old 03-10-2020, 06:55 PM #1
taxzz's Avatar
taxzz taxzz is offline
taxzz will become famous soon enough taxzz will become famous soon enough
taxzz's Avatar
Installed the Victory 4x4 Blitz Bumper w/tube (and winch)
This past weekend I received and installed the Blitz Bumper from @Victory 4x4 on my 2004 Limited V8 (see the full build/maintenance sheet in signature below).
I also installed a Smittybilt 9500lb winch (Amazon URL).
The product and service from Victory were great, no complaints from them. The shipping was a bit of an issue and the shipper ended up losing the whole box, but I wouldn't put that on Victory.
The exact product I bought is located here.
4Runner Front Winch Bumper | Blitz w/Tube | 4th Gen (03-09) - Victory 4x4
You can also find the install instructions PDF for a 5th gen/4th gen here.
Here are some photos with general steps if you plan to tackle this yourself. I did this without removing the entire bumper cover, with as little adjustment as possible.
Here is the before shot;
This is a post cut and bumper removal photo, but you can see what's been removed from the bumper/grill.
I used an angle grinder w/ cutoff wheel, which I don't recommend. A sawzall is going to be easier for most people. I had to cut all of the bottom valance and the bottom 'grill'. I tried to remove the grill without cutting it, but that wasn't going to happen.
I did a bit of cleaning up, but the bumper is going to cover all the edges here, so don't fret too much.
I then removed the front bumper by removing the 4 bolts behind the foam here.
There are 4 nuts on each side which will let you remove the bumper extensions. On the bottom of each of those is two clips holding in a splash guard. I did NOT need to remove the bolts, they were fine so I just pushed the new bumper over them.
I then positioned the bumper to slide on. Have a second pair of hands if you have a winch on this SOB, it's heavy. I did this alone and it added a lot of effort.
Here are some after shots. I used the roller fairlead that came with the Smittybilt winch for a few days, but decided I'd rather have the warn cast iron.
I'll be getting a light bar later, but it would have been an easier install to have it on hand before installing the bumper.
I believe this is my first main how to post on the current rig, so let me know if you have any questions.
Here's a sneak peak of the 1st gen overland trailer build my wife and I are working on. She started a thread over here and will update it soon with the RTT situation and interior build out.
2007 Limited V8 | Apache AX2 and Dobinson 3" lift
2004 Limited V8 | Dobinson IMS Long Travel 3″ lift w/ SPC UCAs | Yoko 35x12.5/17 | Rear Locker | Front LSD !!!!FOR SALE!!!!
2004 SR5 V6 | Sold
taxzz is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 08:41 AM #2
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
Looks good, and good little write-up. I have a C4 Lo-Pro and winch sitting in my garage waiting for me to not be lazy and install lol. I may try not removing the cover like you did.
Do you have a body lift? I'm assuming the only difference would be stretching the bottom of the cover down a little extra to attach it to the bumper.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 10:10 AM #3
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
as an aside, Victory doesnt offer an option for BLs....big lame in my opinion...If I go with Victory I will have a body lift before it goes on. Expecting to have to drill new holes possibly....unless they come out with a BL edition
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 10:20 AM #4
Real Name: Aaron
Real Name: Aaron
Neither does C4, but I believe with this style bumper it won't matter. You don't lift this bumper up since the middle part of the cover stays in place. My factory cover is already "stretched" down to mount at the bottom, and it should be no different with different mounting locations.
Old 03-11-2020, 10:28 AM #5
Real Name: Michael
Real Name: Michael
The bumper cover would be going up though, you may have a gap at the top of the new lopro bumper where the bumper cover was. Not sure how much "overhang" there is
Old 03-11-2020, 03:52 PM #6
Real Name: Aaron
Real Name: Aaron
I'm not sure how much, I'm expecting it to split the difference. I know the top of the cover will go up while the bottom will remain in place. I'm sure it won't be an exactly perfect fit at the top of the new bumper, but we'll see. I think lifting the bumper up the full height of the BL would be too much. Hopefully there's a reason they don't offer those options lol.
Old 03-14-2020, 08:45 AM #7
taxzz's Avatar
taxzz's Avatar
No body lift at all. And i'm sure you can do it without removing the cover.
2004 SR5 V6 | Sold
Old 03-15-2020, 10:02 AM #8
Mr. Banks's Avatar
Mr. Banks Mr. Banks is offline
Mr. Banks is on a distinguished road
Mr. Banks's Avatar
Ride quality?
I thought I read in the 5th gen forums the blitz bumper shakes. That was my only reason for not pulling the trigger. Can you comment on how it rides at highway speeds?
2005 Sport Edition 4.7L V8 4x4
-Borla Dual Exhaust -HCF Delete -OEM 2006 Tail Light MOD -Pioneer AVH-4200NEX -Automatic Start -Lo Jack -Heated Seats Mod -WeatherTech All Weather Floor Mats -Sport Pedals -Black Headlight Housings -ALL LED External Lights -Bilstein 6112/5160 Lift -FJ Coil Swap -C4 Low Pro Bumper -Warn VR Evo 10k-S Winch -Sherpa Princeton roof rack -Extreme LED Light Bars -SCS SR8 wheels on Falken Wildpeak tires 285/70/R17
http://www.toyota-4runner.org/4th-ge...ld-thread.html
Mr. Banks is offline   Reply With QuoteReply With Quote
Old 03-16-2020, 09:49 AM #9
taxzz's Avatar
taxzz's Avatar
No issues for that at all. Not sure what would cause it to shake other than not securely installing it.
2004 SR5 V6 | Sold
Old 03-20-2020, 02:20 PM #10
thuanvu thuanvu is offline
thuanvu will become famous soon enough
Looks good! Will probably wait for the pricing of their new full bumper before jumping in tho.
2004 Limited AWD V8, Icon Stage 2 w/DJ UCA, Nitto Terra Grappler 285/70/17, SCS SR8, Apex Front Recovery Points, Prinsu Roof Rack
thuanvu is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 10:33 AM #11
taxzz's Avatar
taxzz's Avatar
I ended up going with this light bar from amazon
Amazon.com: Rigidhorse 22 Inch LED Light Bar Single Row Flood & Spot Beam Combo 20000LM Off Road LED Light Bar Driving Light for Jeep Pickup SUV ATV UTV Truck Roof Bumper: Automotive
I don't need anything that costs hundreds, as long as this one will keep water out which it has done a fine job of.
2004 SR5 V6 | Sold
Old 06-27-2020, 11:28 AM #12
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
What the heck is the suv behind your's?
Porsche or VW?
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 02:49 PM #13
Pattatted4 Pattatted4 is offline
Pattatted4 is on a distinguished road
Looks great!!! This is on my "to-do" list for my 08 UrbanRunner. How long would you say it took?
Pattatted4 is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 06:16 PM #14
taxzz's Avatar
taxzz's Avatar
3 hours or so. could do it in 1hr now that i did it once before. the second set of hands would go a long way for passing a wrench side to side when bolting the bumper up, and for getting it in place.
2004 SR5 V6 | Sold
Old 06-27-2020, 06:24 PM #15
taxzz's Avatar
taxzz's Avatar
Porsche or VW?
That's a Cayenne, there were two of those and two Touaregs doing a ride earlier this month. YouTube
2004 SR5 V6 | Sold
bumper , installed , remove , victory , winch
Pulled the trigger on a new purchase victory blitz front bumper Mudballz 5th gen T4Rs 12 02-09-2023 05:28 PM
Installed Victory 4X4 BLITZ Aluminum Bumper with HF APEX 12,000 lb Winch Coyotegray 5th gen T4Rs 31 02-21-2022 11:54 AM
Victory 4x4 Bumper, Warn Winch and Dobinsons UCA Installed ProfessorP 5th gen T4Rs 5 08-27-2019 07:43 AM
**CLOSED** Victory 4x4 Sliders (Blitz and Strike Models) | GROUP BUY Victory 4x4 Group Buys 20 03-18-2019 10:55 AM
