Old 03-10-2020, 08:09 PM #1
Mike the Wino's Avatar
Mike the Wino Mike the Wino is offline
Mike the Wino is on a distinguished road
'03 4R towing setup
I did a cursory search and looked at a few threads, but didn't see anything that answered my question(s) which is:
The receiver on my vehicle is super short, I guess due to its proximity to the spare tire.
Because of this, the ball mount only slides in until it contacts the tire (about 4"), and I had to drill a hole in the mount for the pin about only 1-1/2" from the end.
It's worked great for years towing a single-axle utility trailer (1700 lb gross weight), but now I'd like to be able to occasionally tow a larger tandem-axle trailer (6000 lb gross weight) with onboard brakes. I'd never have more than about 2000 lbs in it, nowhere near the max the vehicle is rated for.
This setup doesn't necessarily have to be upgraded, but I wouldn't mind doing something to make it a little more robust. So the first question is, what options are out there to provide a longer receiver that will bolt on like the old one? Or should I just take it to U-Haul and have a custom one installed?
Second, there is a trailer brake circuit, with a fuse, already installed. However, I don't have an under-dash brake controller. Any recommendations for that?
Mike the Wino
"Life is too short to drink bad wine."--Unknown
Mike the Wino is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 08:27 PM #2
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Can't help much with the receiver but for the brake controller I recommend the Tekonsha P3. I've had one on my Tundra for 10 years and it works flawlessly. And I've pulled a tandom axle car trailer loaded a good bit and my 29 ft travel trailer thousands of miles with it. Highly recommend it.
importman is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 08:28 PM #3
importman, thanks for the info! Is your receiver like the one in my photos?
Mike the Wino
Old 03-11-2020, 09:34 AM #4
TheDailyDownshift TheDailyDownshift is offline
TheDailyDownshift is on a distinguished road
See if you can get an aftermarket hitch that bolts to the frame rails, rather than the bumper reinforcement, V8 style. That's one of the main reasons the V8s are rated higher (that, and the transmission cooler).
As for brake controllers, I just installed one of these and this plug and play harness for it. Just bolt the ground down somewhere and plug into the factory hookup by the driver's kick panel.
TheDailyDownshift is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 12:56 PM #5
Andysrt Andysrt is offline
Andysrt is on a distinguished road
Our 03 had that same receiver. Switch out that hitch it sucks for towing much of anything. Get a frame mounted hitch. We got a brake controller from our local RV store it was a easy hook up. If you still have the manual it has a awesome section on towing
Andysrt is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 01:14 PM #6
V8Man's Avatar
V8Man V8Man is offline
V8Man will become famous soon enough V8Man will become famous soon enough
V8Man's Avatar
No Worries!
@Mike the Wino
All 2003 recievers are short like yours. They changed after that. Toyota made a special hitch that came with the truck when new. I have towed a lot with my '03's without any problems.
First picture is the hitch. Second picture is #2 towing #3. Third picture is #3 towing my 64 1/2 Mustang.
'03 4R towing setup-dsc00022-jpg  '03 4R towing setup-img_0867-resize-jpg  '03 4R towing setup-img_2414-resize-jpg
I currently own 4 T4R 4th Gen
#1) 2003 Sport V8 2WD purchased new, totaled @ 175,000.
#2) 2003 SR5 V8 2WD running w/engine from #1(Son#3 is Driving)
#3) 2003 Sport V8 4WD
#4) 2004 Sport V8 Supercharged 4WD
V8Man is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 08:21 PM #7
MikeinNH67's Avatar
MikeinNH67's Avatar
As mentioned, the factory receiver length is short so you have to have a draw bar that is on the short side. One I have fits perfectly but another I have that is for a different height trailer does what yours does. My plan is to cut just enough off the draw bar tool so it fits. 1/4" in my case. You're not pulling anywhere near the max weight so I see no need to get a frame setup unless you really want it. I pull my 3500lb camper with it and a trailer with my small Kubota tractor in the trailer. Pulls great.
As for the electric brakes, so simple to setup assuming you have the proper cable. Any good brand controller is fine, check the reviews and get one that you like the control setup on. Mine is an old style Draw-Tite Activator, been going strong for probably 20 years.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 03-11-2020, 08:39 PM #8
Awesome help everyone! The reassurance is appreciated...thanks so much.
This forum is fantastic!
Mike the Wino
gross , mount , tire , trailer , weight
Rear suspension setup for towing. Rendell 3rd gen T4Rs 24 07-19-2019 12:36 PM
2012 SR5 towing setup advice please Blooze 5th gen T4Rs 11 08-27-2014 07:53 PM
Best setup for towing? jman11788 3rd gen T4Rs 14 01-01-2013 09:02 PM
Best Setup for Towing Paragon1 5th gen T4Rs 12 02-29-2012 01:08 AM
