Old 03-10-2020, 08:59 PM #1
Jacobzky's Avatar
Jacobzky Jacobzky is offline
Jacobzky is on a distinguished road
Jacobzky's Avatar
What coil to pair for Bilstein 5100?
I recently bought a set of Bilstein 5100, can i run it with the stock coil of my 2006 4R SE? If so i notice there are 4 lines on the shock body, where would be the optimum placement of the C-clip?
Any suggestion what Coil just for the front, to pair it with my Bilstein 5100? part number would greatly help. i plan to lift no more than 2" on the front.
Jacobzky is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 01:27 AM #2
FXFRunner FXFRunner is offline
FXFRunner is on a distinguished road
check out my similarly titled recent thread, lol
Which front coils to combine with 5100s?
FXFRunner is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 07:45 AM #3
miller507's Avatar
miller507 miller507 is offline
miller507 will become famous soon enough
miller507's Avatar
I've been running the OME/Bilstein combo for a few years with lots of street/offroad use. 884 with the 5100s on the second notch for the front and 895 for the rear.
Pretty happy with the setup, the 895s were a bit to hard for my liking due to the lack of weight so I switched them for a set of 80 series front coils (yup same combo from the 3rd gen). I'll be adding at least 100-200 pounds of car audio crap so will probably swap them in again.
If you are not planning on doing anything serious offroad, you can get away with stock coils.
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
miller507 is offline   Reply With QuoteReply With Quote
Old 03-16-2020, 12:55 AM #4
Jacobzky's Avatar
Jacobzky's Avatar
I ended up using the stock front and rear coil for now, it looks good, the 5100 set on the 3 line from the bottom and bigger tires gave my4R about less than 2 inch lift and paired with 275/70R17 BFG AT KO2
bilstein , coil , optimum , pair , suggestion
FS: Bilstein 5100 (front pair) Brand New In Box- Part# 24-196499 Dayton, OH $150 Jimfirefitr For Sale: Suspension/Wheels/Tires 1 03-22-2017 10:16 AM
Bilstein 5100's Coil Relacement TrueBlue 4th Gen T4Rs 10 09-12-2016 08:52 PM
coil rotation with bilstein 5100's FrankM23 3rd gen T4Rs 0 05-10-2013 09:50 PM
Bilstein 5100 Loose Coil Spring mjtien 4th Gen T4Rs 3 06-25-2012 01:56 PM
