Old 03-11-2020, 01:30 PM #16
Jayson44's Avatar
Jayson44 Jayson44 is offline
Jayson44 will become famous soon enough
Jayson44's Avatar
Originally Posted by evan1242 View Post
So wire number 2 on the switch that came with the harness needs to go to the blue wire on your new switch.
Then just ground the new switch
Then just wire the 2 left over wires from the new switch to switched ignition power.
awesome. thanks! could I run the 2 together into a fuse line for the fuse box using a fuse tap? or should I find a better source?
J.
05 v8 Sport - K&N air filter - Toytec Ultimate front + OME 3" rear - JBA HD UCAs - Spydertrax spacers - 35" Kenati Trail Hogs - Vors v37s
Jayson44 is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 01:33 PM #17
evan1242's Avatar
evan1242 evan1242 is offline
evan1242 will become famous soon enough evan1242 will become famous soon enough
evan1242's Avatar
J.
No that would be perfectly fine. I would just make sure it is one that turns on and off with the key so light turns off when you turn the key off even if the switch is on.
If your putting the switch in the center console like I did there is switched power right there from the 12v power outlet.
White with a black stripe is positive.
evan1242 is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 02:31 PM #18
Seasparrow Seasparrow is offline
Seasparrow will become famous soon enough
wow.
apparently my powers of perception and general eye-sight are not what I think they are. thanks for pointing out the obvious.
J.
The biggest surprise was that I saw it !!!!!
OK , I am going to have to come clean on this one, I keep my mouse on the left side of my screen when I am reading and I accidentally moused over it...
And that is the truth.
NATO Seasparrow Mk 57 Mod 2 & 3
2004 4th Gen Sport Edition
Seasparrow is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 11:28 PM #19
Jayson44's Avatar
Jayson44's Avatar
ok, so here's the actual diagram from my harness. it's the same as the one above, but I guess the ground and power from the switch go directly to the relay...
so does that mean I can wire those straight into the new switch?
J.
Old 03-12-2020, 01:39 PM #20
evan1242's Avatar
evan1242's Avatar
J.
You could try. But it will probably keep the light on your switch on all the time. If it keeps it on you will have to run the red wire from the old switch to the yellow wire of the new switch. And the from the new switch the red wire would need to go to switched ignition power to turn the light inside the switch on and off.
Blue from the switch would go to white in the harness.
And ground to ground of course.
Old 03-12-2020, 01:44 PM #21
evan1242's Avatar
evan1242's Avatar
Basically on your new switch the red wire is just for the little light in the inside of it.
Old 03-12-2020, 04:25 PM #22
Jayson44's Avatar
Jayson44's Avatar
cool. thanks. can I wire the black on the switch to the black on the harness? or should I ground it on it's own?
basically, can I use the harness for red -> yellow, black -> black, white -> blue and send the red wire from the new switch to ignition?
J.
Old 03-12-2020, 04:27 PM #23
evan1242's Avatar
evan1242's Avatar
J.
You got it man! That should do the trick
Old 03-12-2020, 04:27 PM #24
Jayson44's Avatar
Jayson44's Avatar
thanks!
J.
Old 03-27-2020, 12:48 PM #25
Jayson44's Avatar
Jayson44's Avatar
thanks for everyone's help on this. got it all wired up last night. the only thing is that the back light stays on all the time and doesn't turn on and off with the headlights. if I wanted to be super picky (not sure I care that much yet) and wanted to figure that out, how would I go about it? everything else works great and it looks pretty much factory which is what I was going for.
J.
black , harness , oem , switch , wiring
Wiring harness/Relay kits:Does any brand work RE: cheap to $$ Ditch Lights? rob_dixon General Discussions 1 07-12-2019 10:58 AM
AOB switch and Black Oak lights wiring airbusa380 5th gen T4Rs 47 04-14-2019 02:40 PM
Help with wiring aux lights to mictuning 4th gen light switch subspd 4th Gen T4Rs 2 01-14-2016 04:34 PM
Wiring 3 Rigid Industries lights to 1 switch? Rudy97 3rd gen T4Rs 4 08-24-2012 02:13 PM
Need help on wiring Piaa lights to new Rocker Switch?? gkatmar 4th Gen T4Rs 4 01-22-2012 06:24 PM
