Originally Posted by Jayson44
ok, so here's the actual diagram from my harness. it's the same as the one above, but I guess the ground and power from the switch go directly to the relay...
so does that mean I can wire those straight into the new switch?
J.
You could try. But it will probably keep the light on your switch on all the time. If it keeps it on you will have to run the red wire from the old switch to the yellow wire of the new switch. And the from the new switch the red wire would need to go to switched ignition power to turn the light inside the switch on and off.
Blue from the switch would go to white in the harness.
And ground to ground of course.
