Originally Posted by Jacobzky
I recently bought a set of Bilstein 5100, can i run it with the stock coil of my 2006 4R SE? If so i notice there are 4 lines on the shock body, where would be the optimum placement of the C-clip?
Any suggestion what Coil just for the front, to pair it with my Bilstein 5100? part number would greatly help. i plan to lift no more than 2" on the front.
I've been running the OME/Bilstein combo for a few years with lots of street/offroad use. 884 with the 5100s on the second notch for the front and 895 for the rear.
Pretty happy with the setup, the 895s were a bit to hard for my liking due to the lack of weight so I switched them for a set of 80 series front coils (yup same combo from the 3rd gen). I'll be adding at least 100-200 pounds of car audio crap so will probably swap them in again.
If you are not planning on doing anything serious offroad, you can get away with stock coils.
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
