Old 03-16-2020, 03:24 PM #1
EinVB EinVB is offline
EinVB is on a distinguished road
AC Dash Control Panel Bulb Replacement
I have a 2006 Limited 4Runner. Multiple bulbs have burnt out in my AC, Clock control panel in the dashboard. I've seen where guy have said they replaced with LEDs instead of lame OEMs that keep bruning out... I'm trying to follow thread links but they are too old or something, not finding what exact LED's I need here.
Can someone help me with where I can buy LED lights to replace the OEM's and what their part numbers are (Any direct link would be appreciated!!!)?
Thanks!
2006 4Runner Ltd (Black), Toytec Ultimate Lift, Goodyear Wrangler Duratrac (275-65-18)
EinVB is offline   Reply With QuoteReply With Quote
Old 03-16-2020, 04:08 PM #2
Disregard... Just read somewhere that there is soldering involved to get these LEDs installed, so I'm going to pass on going that route and replace all with OEM's - hopefully I can get another 10 years our of them.
Old 03-16-2020, 04:46 PM #3
Well... now some of these LED bulbs look like they don't need to be soldered to replace these bulbs
90010-09015
90010-09016
90010-09017
90010-09018
90010-09019
Can anyone confirm are these easily plug and play replaceable with the LED's from somewhere - if so... which kind and where can I grab them?
Old 03-16-2020, 05:40 PM #4
MikeinNH67's Avatar
MikeinNH67's Avatar
I don't know about LED but the bulbs below will fit in most locations. They also fit Honda vehicles. At this price you can replace them all at once. I have yet to have one of these fail but I'm sure it will happen eventually. It is a bit more work to replace the bulb seeing you reuse the socket.
CEC Industries 7219 Bulbs, 12 V, 0.72 W, Wire Terminal Base, T-1 shape (Box of 10) - - Amazon.com
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 03-17-2020, 04:37 AM #5
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Not to derail this thread but I've been dealing with these bulbs recently, (normal, not led). The one for the position control switch, (far right) wasn't lighting up so I decided to switch bulbs with the one for the fan speed until I could order new bulbs. After switching I expected the fan switch to be dark and the position switch to light up. But now neither lit up. So I took the bulb from the center switch, (AUTO, temp control etc) and moved it to one of the other locations. Now none of them are lighting up. I tested all of them for power and ground in case I somehow caused a problem but they all had power and ground. I can only assume with their age they just blew because of me messing with them. I'm gonna be ordering some as soon as I can decide what I want to use. I know this is not really relevant to the OP. I just found it so odd the way the bulbs failed on me, I wanted to tell someone about it, lol.
importman is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 08:38 AM #6
@importman ... I would agree... with their age and you fiddling with them a bit, I could see how they might have now blown. Bulbs aren't the most sturdy/stout... especially if they're old.
Old 03-17-2020, 08:42 AM #7
Still interested in knowing where I can buy LED lights to replace the OEM's and what their part numbers are (Any direct link would be appreciated!!!)?
As I mentioned earlier... I have a 2006 Limited 4Runner. Multiple bulbs have burnt out in my AC, Clock control panel in the dashboard and would prefer to replace all of these with LEDs.
OEM Part #'s
90010-09015 (x2)
90010-09016 (x2)
90010-09017 (x2)
90010-09018 (x1)
90010-09019 (x2)
Old 03-17-2020, 09:45 AM #8
sonicc sonicc is offline
sonicc is on a distinguished road
Can you remove one of the bulbs? That way you can see if it's soldered or not. And if it's not soldered, then you can go on a website like superbrightleds.com and find one with same base (plug) as yours.
Also don't be scared of soldering, it's not dark magic.
sonicc is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 02:43 PM #9
they aren't soldered... (I think I got confused by reading some other threads and realized there were talking about soldering LEDS for other interior lights, not these that I'm looking to replace)
How do I find one with same base (plug)?
Old 07-22-2020, 10:37 AM #10
nvmike24 nvmike24 is offline
nvmike24 is on a distinguished road
I found this on FB. Not sure if it helps you.
Facebook
Facebook
nvmike24 is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 11:03 AM #11
We’re the .72watt bulbs bright enough?
Old 07-22-2020, 12:12 PM #12
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Facebook
Facebook
Well those links are useless if someone isn't a: on facebook or b: not a member of that group.
Any chance you can copy/paste the content from there into another post?
Edit: See screenshot here of the facebook links: https://i.imgur.com/g5dAVLC.jpg
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 12:21 PM #13
OLD BOB OLD BOB is offline
Real Name: ROBERT DEWOODY
OLD BOB is on a distinguished road
led bulbs
just go to the Superbright website and put your vehicle in and it will give you the correct bulbs for your application.
rd
OLD BOB is offline   Reply With QuoteReply With Quote
control , exact , leds , oems , panel
Instrument Panel Bulb Replacement Video mtbtim 3rd gen T4Rs 3 03-12-2016 03:12 PM
Climate Control Panel Bulb Replacement loths Engines / Suspension / Wheels / Tires / Audio / Accessories 3 01-15-2015 08:00 PM
Dash bulb replacement Intp Classic T4Rs 2 02-02-2014 07:31 PM
Temp control bulb replacement Shamangue 4th Gen T4Rs 3 12-28-2009 04:35 PM
Replacing Dash Panel Light Bulb SnowFly Classic T4Rs 2 11-06-2006 06:39 PM
