Old 07-22-2020, 01:36 AM #1
Nape4 Nape4 is offline
Nape4 is on a distinguished road
rear hatch wont open again
hello i bought my car like 50 days ago +-
the same day i bought it my rear hatch quit working
i let an electrician mechanic to look on it 4 hours he couldn't find the problem
few weeks after i changed alternator because he quit working
and then he start working again (idk if it was just coincidence)
now i closed it. it made a sound of locking it normal
and didn't open again
what can i do please?
2006 turbo-diesel
Nape4 is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 03:35 AM #2
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
What ultimately worked for me the last time was to unhook the negative battery terminal for a few minutes then do the driver side lock/unlock 3 times. That was after the other tricks failing this time.
There are other things to try that had worked for me prior to them failing. Such as.....
-lock and unlock doors on the driver side 3 times and it worked a few times
-Disconnect battery for a few minutes, then try the tricks again if that didn’t do it
-Disconnect the ECU for it. It is the blue harness behind the panel on rear gate
-There are a couple more that I’m not recalling currently
If anything is going to do it, it would be the ECU disconnect or rear window down/up and hold
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 09:36 AM #3
Syr4RinNC's Avatar
Syr4RinNC's Avatar
When you press the latch release are you getting anY sound? Simple issue I’ve seen is just push hard against it and make sure it’s all the way closed. If that doesn’t work then start going down all the other possible issues
hatch , open , quit , rear , working
Rear Hatch wont open takumi 3rd gen T4Rs 19 01-10-2021 03:41 PM
Rear Hatch Won't Open.... Twins114 4th Gen T4Rs 4 11-27-2013 11:13 AM
No way to open rear hatch with key? MeBe4running 5th gen T4Rs 24 10-22-2012 10:35 PM
rear hatch wont open/normalize locks Northern Bigdoggy 4th Gen T4Rs 2 06-21-2012 02:20 PM
03 rear hatch won't open! mxnmtber Problems & Warranty Issues 4 10-04-2006 08:54 AM
