Old 03-18-2020, 01:21 AM #1
Jasonredwood's Avatar
Jasonredwood Jasonredwood is offline
Jasonredwood is on a distinguished road
Heat not functioning and dash noise
Here this evening. Huddled inside avoiding the virus. Decide that a pizza is in order. Hop in the car to get firewood and pizza and notice we don’t have any heat. About 20 mins in after fusing with the hvac controls we get a little heat and it sounds like there’s a Stoned squirrel runnin around in the dash behind the controls. The Upper radiator hose isn’t pressurizing though. After some googling it sounds like air mix motor or blend door motor, but that’s based off these 3rd gen threads I’m coming across.
Has this been an issue with the 4th gens, I’m sure it has? Anyone familiar with the diagnoses and fix?
Jason
1985 fj60
2006 4runner v8 4x4 sport
http://www.jasonredwoodart.com
Jasonredwood is offline   Reply With QuoteReply With Quote
Old 03-18-2020, 01:14 PM #2
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
If your upper hose isn't getting hot, I'd lean more towards the thermostat as an easy place to start than controls/motors.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 03-18-2020, 01:56 PM #3
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Sounds like a bad actuator motor. To confirm does your coolant temp gauge go to the middle normal position or not? If the gauge reads normal your thermostat and coolant lever are likely fine.
I suspect my blend door is going out too. I get cool air on low and hot on 65 or above. I am biding my time as the book calls for 5 hours for the repair. I have done a few dozen on my fleet vehicles and they are rarely fun.
Best of luck. Let us know how it goes.
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 03-18-2020, 04:01 PM #4
Yeah the coolant gauge goes to the middle as normal.
The radiator over flow hose is getting a work out though. Steam is coming out of the overflow vent hose periodically.
As long as the temp stays in the normal range we should be okay to use the truck yeah?
Jason
1985 fj60
controls , heat , i’m , motor , sounds
89 Runner dash Heat akrunning Classic T4Rs 1 11-03-2018 01:53 AM
Dash/heat/windows dead Myrunr2010 3rd gen T4Rs 10 11-09-2016 07:33 AM
noise from behind dash no heat sjoefl01 4th Gen T4Rs 3 09-14-2015 10:29 PM
No heat -dash control arm stuck mrfastvrod 3rd gen T4Rs 2 02-16-2013 02:24 PM
No heat drivers side dash drmorbius 4th Gen T4Rs 2 12-07-2011 11:54 AM
