Old 07-06-2020, 08:38 PM #1
TheHennDoggg's Avatar
TheHennDoggg TheHennDoggg is offline
Real Name: Henry
TheHennDoggg will become famous soon enough
Real Name: Henry
V8 O2 Sensor code- Coincidence?
Hey guys, I have an 03 V8 4runner.
I was about to install a Doug Thorley y-pipe onto stock headers when I stripped an exhaust stud on the passenger side flange between the y-pipe and the header. No big deal, I ordered a new stud and hardware to swap out. Fast forward to today, I couldn't for the life of me get the stud out of the rusty flange and decided to put off the install for further down the line.
Driving it to work, I got a CEL the code P0051 (which I have never gotten before) so I attributed to the small exhaust leak I made that is right before the downstream 02 sensor. The code, however, is for Bank 2 Sensor 1, the upstream sensor (???) I put a quick bead of weld on the flange to close the leak and plan to use some exhaust putty/tape to seal it and see if the code goes away, but why would I get an upstream code when all I messed with was the area after the primary catalytic converters?
The full code is: P0051 H02S Heater Control Circuit Low Bank 2 Sensor 1
It would just be an insane coincidence that the upstream sensor died when I was doing this job. Also, the 4Runner runs perfect, leading me to believe it is probably not the upstream A/F sensors. I guess this is what I get for fixing something that wasn't broken
Ask me about my frame rust!
Major Parts List:
Energy Suspension, full front end rebuild, 885& Toytec, SPC upper arms, dual-amped 7 speaker stereo, 5100's, rear swaybar delete courtesy of rust, v6 junkyard skidplates and a lot of elbow grease
TheHennDoggg is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 07:12 PM #2
Real Name: Henry
Real Name: Henry
Well boys, $80 later and a brand new Denso #234-4138, it WAS a coincidence! CEL eliminated. That threw me for a quick loop but I'm glad it wasn't something more serious.
Major Parts List:
code , exhaust , flange , sensor , upstream
H02 Sensor (Bank 1 Sensor 2) P0136 Code??? petepup Maintenance/Detailing 32 01-06-2023 06:49 PM
MAF sensor relearn? MAF code after 02 sensor change shahsmerdis 4th Gen T4Rs 7 08-30-2018 03:56 PM
P0141 Code - Which o2 Sensor Rusty Shackleford 3rd gen T4Rs 14 09-22-2014 12:40 AM
'06 O2 Sensor Code? cnl390 4th Gen T4Rs 7 09-19-2012 09:46 PM
P2238 code / where is the sensor? ZonaT4R Problems & Warranty Issues 7 05-26-2006 12:46 PM
