Old 07-01-2020, 08:47 AM #1
montijo505's Avatar
montijo505's Avatar
Tire plug?
I took the runner to have a tire patched. I didn't notice until I left that they used a rubber plug. Is this safe for highway use? Or meant as temporary? Thanks.
Sent from my SM-G986U using Tapatalk
Old 07-01-2020, 09:47 AM #2
Burt Burt is offline
Burt is on a distinguished road
Sure is. What were you expecting a plug to be?
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
Burt is offline   Reply With QuoteReply With Quote
Old 07-01-2020, 11:14 AM #3
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
It is safe. A tire can be patched/plugged if the hole is in the tread. If the hole is in the sidewall, you need to get a new tire.
The plug is a permanent fix, not a temporary one.
ads2539 is offline   Reply With QuoteReply With Quote
Old 07-01-2020, 04:16 PM #4
montijo505's Avatar
montijo505's Avatar
Have a nice day my dude.
Old 07-01-2020, 04:17 PM #5
montijo505's Avatar
montijo505's Avatar
Thanks. Just never seen a plug it's always been a patch on the inside.
Old 07-01-2020, 04:23 PM #6
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Most reputable tire stores won't plug a tire anymore. I saw a display once that showed what the inside of a tire can look like when it's punctured. The outside had a tiny hole but the inside was ripped open. That being said, I've used plenty of plugs over the years with no problems. You should be fine.
importman is offline   Reply With QuoteReply With Quote
Old 07-01-2020, 04:27 PM #7
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Being an old school tire guy, I use a plug to get me to where the tire can be patched.
I have seen plugs lead to ply separation.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 07-02-2020, 02:08 AM #8
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
That probably is a patch with a built-in stem/plug Stem Repairs - Dura-Vulc Most tire plugs look like rough cord or string dipped in rubber, and whoever installed that patch should've trimmed off that protruding piece.
Old 07-06-2020, 11:36 PM #9
MikeinNH67's Avatar
MikeinNH67's Avatar
This is similar to the last one I had repaired. Patch with a built in plug.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 07-07-2020, 01:52 AM #10
montijo505's Avatar
montijo505's Avatar
Thanks, I'll go ahead and swap it back on for a while and see what it does.
I am never buying LT tires again, next time will be at least a c load. I never had to get a flat fixed in 5 years on my Nitto Trail Grapplers E loads. Those tires saw a lot of dirt too. I've had this set for a year and this was my second tire repair, and these have been all asphalt unfortunately.
Maybe I'll just get some STT Maxx in E and avoid the headache.
Old 07-07-2020, 03:59 PM #11
MikeinNH67's Avatar
MikeinNH67's Avatar
Mine had a hunk of steel shoved through the tread. That was my wife's van with almost new Michelins.
Mike
03 4runner Limited
plug , safe , sm-g986u , temporary , tire
Those with the S&B Intake: Box plug or no box plug? Nuke 5th gen T4Rs 0 10-24-2019 10:28 AM
4 pole flat trailer plug- how are you storing them? plug 2ndhandyotaman 3rd gen T4Rs 5 04-04-2018 11:09 AM
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto Rockauto 0 01-12-2017 02:52 PM
FS: 2016 4runner Trail - 4 Wheel/Tire Combo + 1 spare tire (Houston, TX) brg128 For Sale: Suspension/Wheels/Tires 2 03-21-2016 08:54 AM
Tire help - which load rating & tire--- Any input on the Kumho KL61 P vs KL78 E ?? FLynFish Engines / Suspension / Wheels / Tires / Audio / Accessories 4 06-13-2013 10:40 AM
