Old 03-31-2020, 05:30 PM #1
chris.817's Avatar
chris.817 chris.817 is offline
chris.817 is on a distinguished road
chris.817's Avatar
DIY Tire Carrier
Hey folks,
Just finished this build and thought I'd share. First, thanks go out to Adventurous Mind on YouTube for the inspiration. I sourced parts from his links and also re-designed based on his complaints on his build. Sorry, no fancy video, just pictures.
The complaints I addressed were the through bumper mount and the too thin metal used for the center support. This version goes straight through the bumper so it can be installed and removed with the bumper in place. It bolts directly to the chassis and I sleeved the tubing so it would not crush. I have not decided on what to put on the driver's side at this point so it is unused. My lesson learned would be to mount the tire to the plate and weld on the lug bolts versus drilling and pressing them in. They do not line up well enough for the sleeved lug nuts. Also, I only used one latch. Seemed plenty.
After a couple days of using it I can say that it is rock solid. It has not been off road but I don't anticipate issues. Fingers crossed.
DIY Tire Carrier-img_2810-sm-jpg  DIY Tire Carrier-img_2812-sm-jpg  DIY Tire Carrier-img_2813-sm-jpg  DIY Tire Carrier-img_2814-sm-jpg  DIY Tire Carrier-img_2815-sm-jpg
chris.817 is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 05:42 PM #2
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Very well done! Ive been contemplating doing this as well. Really like that the hitch is still accessible!
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 05:58 PM #3
Caldizzle's Avatar
Caldizzle Caldizzle is offline
Real Name: Calvin
Caldizzle will become famous soon enough
Caldizzle's Avatar
Real Name: Calvin
Nice! I have a double shear mount sitting in my garage waiting for some time to do just this! Do you have a picture of how it mounts to the frame? I had considered just welding it on, but if it's pretty solid just bolted on...
2006 Sport Edition 4x4 V8
Bilstein 6112 w/ King 700# springs (5th clip), Toytec 2" springs in the rear w/ ICON 2.0,
CBI single hoop front bumper, Smittybilt 9500 XRC, RCI steel full skid package, 285/70r17 BFG KO2s on TRD Offroad wheels
Caldizzle is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 06:45 PM #4
chris.817's Avatar
chris.817's Avatar
Don't weld it on...
I sleeved and boxed the tubing. I welded 1/2" nuts to a backing plate, cut the cap off the chassis (see yellow), welded in the backing plate, then welded the chassis cap back on. My buddy is holding one in place. The extensions then bolt to these nuts through holes drilled in the chassis. This makes the extensions removable which they certainly need to be so the bumper can be removed in the future.
I'm pretty sure these could double as tow points. And please no welding jokes... I'm learning.
DIY Tire Carrier-img_2732-sm-jpg  DIY Tire Carrier-img_2738-sm-jpg  DIY Tire Carrier-img_2739-sm-jpg  DIY Tire Carrier-img_2751-sm-jpg  DIY Tire Carrier-img_2817-sm-jpg
Old 03-31-2020, 08:50 PM #5
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Wow, that looks great.
I would consider buying that if you were producing them. Hint Hint
Old 03-31-2020, 09:07 PM #6
Caldizzle's Avatar
Real Name: Calvin
Caldizzle's Avatar
Real Name: Calvin
Awesome...thanks for the info. The thought had crossed my mind that I didn't want two huge slits going up through the bumper. I will definitely dip into your design a little bit to add on to what I had in mind.
Ha, I don't expect near that level of welds, it will be my first time, learning from a friend.
Happy to see a few more posts of this kind of stuff, I don't want/need a full steel rear bumper, and the Wilco is way overpriced and bulky IMO, along with taking up the hitch. This type of carrier seems to be easy enough and fits my criteria. Good job again
Old 03-31-2020, 09:51 PM #7
KrazedJD's Avatar
KrazedJD KrazedJD is offline
KrazedJD is on a distinguished road
KrazedJD's Avatar
Great job and excellent idea! You could totally manufacture this and sell it!
Do you have a closeup of the locking pin assembly?
KrazedJD is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 10:58 PM #8
chris.817's Avatar
chris.817's Avatar
Locking pin
The locking pins are two piece. The pin/handle/spring and the threaded sleeve.
First picture is the sleeve tacked to mounts I built. I added a ramp for them to lock into in second picture (also shows boxed end and corner gusset). Third picture is finished product. I can release them for full open.
DIY Tire Carrier-img_2781-sm-jpg  DIY Tire Carrier-img_2786-sm-cropped-ramp-jpg  DIY Tire Carrier-img_2811-sm-jpg
1999 4Runner Highlander (original owner) 225k miles - all original
2004 4Runner Limited 4.0 170k miles - DIY inside OEM bumper 12k winch, DIY tire carrier
Old 04-01-2020, 03:58 AM #9
kodenco's Avatar
kodenco kodenco is offline
kodenco is on a distinguished road
kodenco's Avatar
This is badass! Exactly what I’m looking for! OP, do you plan on making more than one?
kodenco is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 10:10 AM #10
thuanvu thuanvu is offline
thuanvu will become famous soon enough
I second the motion. All in favor?
2004 Limited AWD V8, Icon Stage 2 w/DJ UCA, Nitto Terra Grappler 285/70/17, SCS SR8, Apex Front Recovery Points, Prinsu Roof Rack
thuanvu is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 03:33 PM #11
KrazedJD's Avatar
KrazedJD's Avatar
Originally Posted by thuanvu View Post
i second the motion. All in favor?
aye!
Old 04-01-2020, 03:34 PM #12
Auditechnician Auditechnician is offline
Auditechnician is on a distinguished road
Much want. Would buy.
Auditechnician is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 07:03 PM #13
MT Runner's Avatar
MT Runner MT Runner is offline
MT Runner will become famous soon enough
MT Runner's Avatar
This is a great setup, I’d be down for one for sure if you were so inclined to build a few
2005 SR5 V6
URD headers and MAF Cal
AFE Intake
Dobinson, JBA UCA’s, 255/75R17 KO2’s, Level 8 MK6 wheels
MT Runner is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 08:09 PM #14
chris.817's Avatar
chris.817's Avatar
Some assembly required
Folks,
I did this project because I didn't want to spend the money on a bumper and all the accessories. They are very nice but cost as much as I paid for the vehicle... I also thought I could give back here by providing the process I followed based originally off the one I found on youtube. I can provide all the measurements to save you a lot of time, trial and error. I'm not a fabricator nor is this kind of stuff a business for me.
All that said, I'm willing to duplicate it for someone. There are two catches.
First, it does require welding on the chassis to access the inside of the boxed frame to insert the backing plate and nuts. I don't see any way around it. See picture of corner that must be removed and re-welded. It's no big deal but has to be done.
Second, the center brace was fabricated on the vehicle to match the supports with the weight of the tire in place. I don't believe that's a show stopper but would have to test a theory to be sure.
If anyone is really serious and wants to be a test case, just PM me. We can see if I can do it for a price that's reasonable.
Thanks again for all the positive feedback. I really appreciate it.
Stay tuned for the winch mount...
Chris
DIY Tire Carrier-img_2732-crop-jpg
Old 04-02-2020, 03:46 PM #15
Fozzy_Bear Fozzy_Bear is offline
Fozzy_Bear is on a distinguished road
Great idea and maintains OEM look
Fozzy_Bear is offline   Reply With QuoteReply With Quote
bumper , complaints , lug , mount , tire
Someone needs to offer a tire carrier like the HUMVEE tire carrier. Road Bull 3rd gen T4Rs 21 07-09-2017 05:03 AM
WTB: Gen 4 Roof Rack, Rear Bumper with Carrier or hitch mounted tire carrier yotanoob Want to Buy/Trade 0 11-23-2016 01:15 AM
Tire Gate Spare Tire Carrier $500 TravelWest01 For Sale: T4R Items 4 11-16-2015 12:41 AM
WTB: 4th Gen Spare Tire Carrier and Carrier Guide jkemp Want to Buy/Trade 0 10-09-2015 02:17 PM
